Go Back   The RadioReference.com Forums > Topic Specific Forums > Radio Equipment Installation Forum
Radio Equipment Installation Forum Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 06-21-2009, 11:33 PM
Default Need mount for Kenwood TM-D700A
Does anybody know where to get a mount for the control head for the TM-D700A? I am looking for the Panavise/RamMount/etc... type. And/Or I need to find a replacement for the part that hold the control head that is the OEM part from Kenwood, but for some reason I cannot find the part on line (the one that holds the head and has the double sided tape on it (and kind of looks like an outstretched peacock as the base).
Any help would be much appreciated.
Old 06-22-2009, 02:09 AM
tmfok7's Avatar
Have you tried the Kenwood site? I believe the "peacock" looking mount is still used for the TM-D710...or at least the brochure I saw showed one that still looked like the one from the TM-D700! You might check with someone like Amateur Electronic Supply in Las Vegas or Ham Radio Outlet in I believe Sunnyvale.
Good luck!
Blessed are the flexible... for they shall not be bent out of shape!
______________
Too Much Fun...OK!
Old 06-25-2009, 09:49 AM
Send a message via AIM to fineshot1
Default Lido Mounts
I have use these and they work great - perhaps you will find one to suit your needs.
Mounting Solutions For Amateur Radio
fineshot1
NJ USA
Old 06-25-2009, 12:17 PM
W9RXR's Avatar
According to the Kenwood TM-D700 instruction manual, the "front panel mounting bracket" parts are: J29-0663-XX and J29-0664-XX. One part is the piece that the head snaps into and the other is the mounting base.
From the Kenwood TM-D710 instruction manual, the "panel holder" is J29-0663-XX and the "panel bracket" is J29-0707-XX. I believe "panel holder" is Kenwood's terminology for the piece that the head snaps into.
I know for a fact that a D710 head will snap into a D700 "panel holder" because I've done it.
My suggestion would be to contact either of the Kenwood parts depots (see Kenwood) to see if you can buy the part. I just did a search on PacParts web site and found the J29-0663-13 in stock for $6.66.
As for Lido mounts, I had one that I was using for a GPS receiver and I wasn't impressed. The mount would not retain tension on the swivel part of the mount so the GPS receiver would not stay upright. I switched to a RAM mount and find that it works much better.
Old 06-25-2009, 01:46 PM
Thank you so much for your detailed response. Do you have the specific ram mount part number you are using for your TM-D700 control head, by any chance?
Thanks again.
Old 06-25-2009, 05:41 PM
W9RXR's Avatar
I'm using the standard Kenwood mount for the head. I use a RAM mount for the GPS receiver.
Similar Threads
NMO Mag Mount Base (Or trunk lip mount) - Any Recommendations? Smerri Antennas and Coax Forum 11 01-13-2009 01:15 PM
Hatchback mount with dual lip dilemma solved N9JIG Radio Equipment Installation Forum 4 12-16-2008 10:20 PM
Arizona Frequency Challenge - Part I FLANO Arizona Radio Discussion Forum 41 10-17-2008 09:39 PM
FS: Uniden Pro-520XL CB Radio + Antenna + Mount AtomicTaco Old Classifieds Archives 2 08-06-2008 05:22 AM
Trunk Lip Mount vs. Hole Mount with the Phantom rmcclellan Antennas and Coax Forum 10 11-25-2005 10:23 PM
