Go Back   The RadioReference.com Forums > Topic Specific Forums > Radio Equipment Installation Forum
Radio Equipment Installation Forum Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 07-17-2009, 08:01 PM
paramedszaf's Avatar
Send a message via AIM to paramedszaf
Default 06' Silverado wiring help!
Alright, spent a good part of the day fabricating my own console (did an alright job with the exception of a 1/4" here or there)
Did a shit job on my last wiring attempt and have to try something better.
Can anyone point me in the direction to get the following into the cab SOMEWHERE (I can deal with distance if necessary.
3 sections of coax (VHF, UHF and scanner antennas)
1 10ga positive
1 10 ga negative
I have stared at the engine compatrment and every imaginable section of the truck looking for a cheat to get inside...
Anyone?
I will post link to thread with my "work in progress"
HT-1250 VHF
HT-1550XLS VHF
CDM 1550 VHF (mobile install)
CDM 1250 UHF (mobile install)
Pro 1018
BCT 7
SC 150B
M1225 VHF x2
BC780XLT x4
BCT15 x2
And more to come!
Old 07-17-2009, 08:57 PM
crazyboy's Avatar
Drill the roof and the coax will be in the cab, the whole car is the negative, and you should be able to find a grommet that you can fit a 10 ga through. If not its not that bad to drill a new one.
Admin : East Coast Scanning Resources
Old 07-17-2009, 09:16 PM
Wirelessly posted (BlackBerry8330/4.5.0.77 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/105)
No can do on the drilling the roof (sorry guys a lease) have to be careful..
Anything else?
HT-1250 VHF
HT-1550XLS VHF
Pro 1018
BCT 7
SC 150B
M1225 VHF x2
BC780XLT x4
BCT15 x2
And more to come!
Old 07-18-2009, 12:15 PM
crazyboy's Avatar
How were you planning on mounting the antennas?
Old 07-18-2009, 09:23 PM
Lip mount the VHF / UHF (already have em') and probably a mag mount for the scanners...
HT-1250 VHF
HT-1550XLS VHF
Pro 1018
BCT 7
SC 150B
M1225 VHF x2
BC780XLT x4
BCT15 x2
And more to come!
Old 07-19-2009, 12:06 AM
There are two places you can drill the firewall easily (do you think the lease company will look at it that detailed?). One is above the gas pedal, you can see about a 1.25" hole in the black plastic covering the insulation and the drill centering dot. You can see the same hole on the engine side of the firewall with the same hole in thee insulation too. The other is above the floor electrical center (where you plug in things like the trailer brake controller). There is about a 3" circle lightly molded in the rubber covering and a tab at the top you grab and pull. You will then see the little drill centering dot in the center. You will have to feel behind the computer module mounted by the bake booster and pull the insulation out of the way to get to it, its held by a plastic push on nut. That one was easiest to drill by removing the fender brace and then the plastic covering over the underhood electrical center. I then moved some of the wiring and unplugged the ones going to that computer module (IIRC it is for the electric throttle control) so I woldn't hit any of it with the drill bit.
Radio Shack Pro 97 Scanner
Midland 75-820 CB
Cobra 25 NW WX ST CB
Similar Threads
'06 Silverado Antenna Help jonmruss Radio Equipment Installation Forum 15 02-10-2009 10:55 PM
FT-8800 install in my 06 Silverado K3XLT Pictures Of Your Shack/Mobile Setup 12 12-29-2007 09:18 PM
06 Chevy Silverado Installation K3XLT Radio Equipment Installation Forum 6 11-27-2007 11:21 PM
Alliance tenna rotor wiring chuckinnc Antennas and Coax Forum 0 11-03-2006 11:00 AM
Zone 3 Talkgroups williams63 Eastern Canada Radio Discussion Forum 9 09-14-2006 01:50 PM
