Originally Posted by N0YFE
The first question I have is what are you looking at powering. A rough guess would be you have a 10 amp fuse for the outlet and if all the items you wish to use add up below 10 amps you should be fine.
Looking at powering:
Uniden RH96
Uniden Bearcat External Speaker
either the Uniden 396T or UBC72XLT
The 396T will normally be in the boot powered of its own power plug in the boot (trunk) with cords running up front to the RH96 and speaker while the 72XLT will be up front with its own power and using the internal speaker.
