Go Back   The RadioReference.com Forums > Topic Specific Forums > Radio Equipment Installation Forum
Radio Equipment Installation Forum Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 08-15-2009, 10:18 AM
Default Antenna for Scanner
I need a decent antenna for my 396T scanner, it will be trunk lip mounted so it cant be too huge.I generally listen to 400-470mhz Police/Fire/Ambulance but very rarely listen to Air aswell. Any help would be great. Especially prefer exact model names and links if possible.
Also ondering if its ok to mount 2 scanners to one antenna?
Old 08-15-2009, 08:35 PM
n4yek's Avatar
Diamond NR72BNMO
Diamond® Antenna ~ NR72BNMO Dualband Mobile Antenna
Comteco Antenna
http://www.scannermaster.com/Comtelc.../07-540719.htm
Here is a link for the antenna/scanner question:
Using one antenna with multiple scanners
Danny Harp Jr.
HAM Radio Operator: N4YEK
Old 08-19-2009, 10:03 AM
Cant seem to get NMO mount in Sydney. so will likely get the SCATX from this page Untitled Document
Old 08-19-2009, 10:29 AM
khoelldobler's Avatar
MOBILE POLICE SCANNER ANTENNA KIT TRUNK LIP / LID MOUNT - eBay (item 220467801762 end time Sep-15-09 20:04:43 PDT)
the above link, or if it doesnt work as a link, can be copy and pasted in your search bar, and it shall take you to an ebay item for sale... its a 30.00 dollar trunk mounted scanner antenna... it covers 25 Mhz to 1.2 Ghz (all band coverage) and it also comes with a BNC connector for attatchment to a scanner that has a BNC connector. Its hieght is not that tall, and It might work well for you. Good luck.
KEVIN HOELLDOBLER
PRO-106 DIGITAL / PSRedit500 SOFTWARE
UBC3300XLT / BUTEL SOFTWARE
PRO-2006 WELL MODIFIED
PRO-2038
PRO-89
and a few MOTOROLA 2 way radios
Old 09-22-2009, 08:06 PM
Default Mobile scanner question
I recently purchased the Comteco Antenna for my truck. The antenna is great but as I look at the photos from Scannermaster I see that the coil (or the larger section in the middle of the antenna) in located on the lower part of the antenna. Mine on the other hand has been placed on the top end of the antenna. I'm not sure if this was a manufacturing mistake over its fine. Any help would be great.
Similar Threads
Larsen Antenna &CheapHam bator Antennas and Coax Forum 8 04-09-2009 06:06 PM
groundplane question snakecharmer Antennas and Coax Forum 24 07-11-2008 10:39 AM
cb ant. next to vhf/uhf motolover Antennas and Coax Forum 4 06-27-2008 10:18 AM
Indoor Attic Antenna for High Def Dish Network tuner cousinvinny Antennas and Coax Forum 5 07-08-2007 02:16 AM
RS 800Mhz antenna on RS Pro95 handheld radunn Antennas and Coax Forum 27 09-23-2004 10:44 AM
