Go Back   The RadioReference.com Forums > Topic Specific Forums > Radio Equipment Installation Forum
Radio Equipment Installation Forum Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 08-25-2009, 08:03 PM
Send a message via AIM to atlong Send a message via Yahoo to atlong
Default Audio Output from Pro-2096 to Alpine Head Unit?
Hi all...
I'm planning on installing a new Alpine head unit with multiple RCA stereo inputs available. I want to utilize my 2000 Civic-Si's double-DIN opening in the dash to install a Pro-2096 radio below the head unit. My question is--I planned on running a short audio cable (1/8" stereo male cable to RCA red/white male) from the external speaker output of the 2096 to the RCA inputs on the back of the Alpine head unit. Will this audio setup work? I'm thinking that the audio may end up being distorted since it's not a line-in source. Any ideas or remedies for this? I really want to avoid installing a separate external speaker for the scanner and obviously can't run a cable from the headset jack on the front to the back of the head unit for much of the same issue.
Thanks for any assistance in advance.
Andy
Andy Long
RadioReference.Com Database Administrator
Old 08-26-2009, 08:53 AM
izzyj4's Avatar
The first problem you are going to have is obviously connecting the mono output of the scanner to the stereo auxiliary inputs. If you use a mini plug to RCA stereo set audio will only come out the left side speakers (natural mono set on the mini plug). You will need a mono mini plug to two RCA jacks that will carry the mono signal.
As for distortion, you will have to experiment with the volume control of the scanner. If you set it about halfway (50%) then adjust the volume on your head unit to a reasonable listening level then you should have good results. You'll have to play with both the scanner and radio volumes to get your desired listening volume.
The major problem with this set up is that you will not be able to listen to the scanner and listen to the radio at the same time. Since you will be pluging the scanner into the auxiliary input of the head unit, you can only select one input at a time (AM / FM / CD / HD radio / Sat Radio). Also, with this set up you will not be able to listen to the scanner since you are using the output jack, it by-passes the scanner's internal speaker. Me personally, I would not use this particular set up as it ties up an auxiliary output of your head unit which you may want to add something like an iPod / MP3 player or Sat radio to the fold. Also you can't listen to any music / talk radio through this set up and trying to find a mono mini jack to dual RCA wire is hard.
Spend the money in getting a small but decent external speaker. You can pick one up for like $10 - $20 at a Radio Shack, truck stop or HAM store. That is your best bet in my opinion.
Similar Threads
PRO 2096 Control kgowen44 Scanner Programming Software 1 12-31-2008 06:15 PM
Pro 2096 stops scanning mfmargetis Radio Shack Scanners 2 04-05-2007 08:18 AM
Norther Va Pro 2096 user? 2004walt Virginia Radio Discussion Forum 2 02-05-2007 07:42 AM
Increase BC250D audio output? hastingsmedic Uniden Scanners 2 04-04-2006 07:27 AM
