I have an amateur radio mobile (Yaesu FT 8800) that I want to install in my 2008 Ford Taurus X. For those unfamiliar, this is what Ford originally called the Freestyle but with a bigger engine and six-speed transmission. Because of the different drive train I'm not sure if access to the engine compartment is the same as the Freestyle.
I need to run power to the battery, but if that proves too difficult I'd consider taking power from one of the 12-volt power points in the center console- I just need a tip on how to access this.
Antenna is a Diamond roof rack mount that I'll run into the back door to the radio chassis under the seat. I've decided to put the control head on the console just in front of the shifter.
Any hints gladly accepted, here, or at
KA2BQJ@aol.com
Thanks! 73
