Go Back   The RadioReference.com Forums > Topic Specific Forums > Radio Equipment Installation Forum
Radio Equipment Installation Forum Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 09-03-2009, 11:30 AM
Default Relay wiring question
I'd like to set up a 'master switch' for my radio equipment, and I'm thinking of using a 4 pin automotive relay to do so.
Would it be wise to switch the negative side, or the positive side? I've heard of it being done in both ways. What I'm switching is the lead running from the battery to the barrier strip that distributes power to the radio, GPS, and 5v power supply.
The relay pinouts are:
86 Ground
30 Input
87 Output when relay is active
85 Positive input to trigger relay coil.
Old 09-03-2009, 12:42 PM
N_Jay's Avatar
Switch the hot.
Some posts can be interpreted as either humorous or insulting
When not sure, always assume humorous
If you only find it insulting you have misunderstood my post or I have misunderstood your post
Old 09-03-2009, 12:51 PM
Mind if I ask why you're using a relay? Is the barrier strip going to be at a different voltage?
Typically, a relay is used to electrically isolate two circuits while using one to switch the other.
Any reason you couldn't just use a plain old rocker switch?
And I agree with N_Jay, switch the hot.
Timothy D. Bennett/KJ4MUY
Cape Coral, Lee County, SW FL
Uniden BCD396XT, ICOM IC-706MKIIG
Old 09-03-2009, 12:57 PM
N_Jay's Avatar
you use the relay to not run the heavy to the switch location.
Old 09-03-2009, 12:58 PM
Citywide173's Avatar
When using a relay in a master switch configuration, you're allowing the relay to handle the load (which it's made to do) and allowing the switch to be of a nominal draw. If you used a 20 amp switch, it could possibly be done depending on the specific radios being used, but the relay with a 5 amp switch is a safer option, as you don't have to worry about excessive load on the switch and the fire hazard associated with it.
I also agree, switch the hot side.
Ed Burke
Webmaster-Fireground Photos.net
Administrator-Firepics.net
Boston Citywide Fire Radio Car 173
Providence Citywide Fire Network Car 173
KB1CTN
WQIL960
Old 09-03-2009, 01:29 PM
Yep, my purpose of the relay is to have a smaller, discrete on/off switch that can shut off the whole works. Thanks for the input and comments, I will switch the hot side.
Old 09-03-2009, 11:41 PM
Send a message via AIM to jparks29 Send a message via MSN to jparks29 Send a message via Yahoo to jparks29
make sure to use a diode to block voltage spikes...
Similar Threads
Whip Antenna Question njt462 Antennas and Coax Forum 15 02-14-2009 12:58 PM
Another newbie question - BR330T Quick Keys scrosby2 Scanner Programming Software 5 08-28-2007 01:50 PM
Repeater Question cookiend15 New York Radio Discussion Forum 5 06-25-2007 12:53 PM
prepurchase research question powerhouse HF/MW/LW General Discussion 5 03-04-2007 11:04 AM
Manual programming question manross Radio Shack Scanners 2 01-10-2007 10:31 PM
