Got bored today so went out and bought the enclosure. The enclosure i bought can be seen here
Mini ABS Instrument Case - Jaycar Electronics on the gray front face i have installed a flick switch which will act as a power on/off and next to that i have put a 3.5mm Stereo jack for if i want to use headphones. On the other side i have put a little red LED light simply because every DIY project must have one lol it will simply light up when the unit is on.
I have decided that if i take out the battery pack and simply run it off power in the car i can install all the scanner components inside the casing. This will include the keypad which will most likely be installed inside (Meaning you have to take the top off to access it, however i very rarely ever use it anyway as this will likely just stick on 1 or 2 local frequencies)
i will install the screen later in the week along with volume and squelch knobs. The antenna connection, power input and air vents will be located on the back face.
