Go Back   The RadioReference.com Forums > Topic Specific Forums > Radio Equipment Installation Forum
Radio Equipment Installation Forum Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 10-05-2009, 11:14 AM
KG4INW's Avatar
Default 2000 Chevy S10 firewall
Hello All, I'm installing a Kenwood TM-V71A into my 2000 Chevy S10 and was wondering if anyone had a suggestion for the best place to go through the firewall with the power cables? Thanks in advance.
Old 10-10-2009, 02:18 PM
Pull back the carpet on the passenger side of the truck where it meets the firewall. There should be a plastic wiring channel. Above the channel you should see a big rubber grommet for the antenna coax. This is probably the easiest spot to run a wire or drill another hole. Its a bit low on the firewall so make sure you seal it well.
Old 10-10-2009, 07:54 PM
mr_tunz's Avatar
Send a message via MSN to mr_tunz
Driver side is usally a good place to go. There is always extra space on the driver side and ur not dealing with the huge heater box. There room in the harness that run up to the engine.
Old 10-11-2009, 07:23 PM
KG4INW's Avatar
Alright, thank you very much! I'll poke around some more when I get some time.
Old 10-18-2009, 10:44 AM
OC05450R's Avatar
If you s10 is manual tranny then you will need to find a grommet or drill a new hole. However if the s10 is an automatic look for the block off plate where the master cylinder for the clutch would be and you can put a hole in there. Good luck with the install -JOEYD
MECP Advance Installer
Radio:
Kenwood tk-8180k 30w 450-520mhz w/ KRK-10 remote mount kit
Maxrad 380-520mhz antenna nmo mount
Old 10-24-2009, 09:51 PM
KG4INW's Avatar
Thanks again for the tips. I was able to go through an existing grommet on the driver's side and it has been working very well for me. Very satisfying to finally finish.
Old 10-24-2009, 10:58 PM
KT4HX's Avatar
Send a message via Yahoo to KT4HX
Where exactly is the grommet you found to use?
Alan
Scanners: PSR-600 | PRO-106 | BCT-15
Old 10-26-2009, 11:11 AM
KG4INW's Avatar
I used the same grommet that the main wiring harness goes through. There's a lot of extra space to the left of the main bundle and although the rubber's pretty thick and interior access is tight, it wasn't too hard to work with.
Old 11-08-2009, 04:19 AM
tmfok7's Avatar
So you have to post a picture of the install! I have a TM-V71 too and have some ideas as to what I want to do but always like see other peoples work.
Blessed are the flexible... for they shall not be bent out of shape!
______________
Too Much Fun...OK!
Old 11-08-2009, 07:46 AM
bep bep is offline
Send a message via AIM to bep
I second tmfok7 request. Very tight for mounting anything in this truck. Looking for ideas.
Old 11-08-2009, 01:37 PM
KG4INW's Avatar
OK, I'll post pictures as soon as I can get to the truck! Probably tomorrow.
Old 11-16-2009, 01:47 PM
KG4INW's Avatar
Whew, sorry for the delay so here are some photos of the radio in my truck. It's mounted on a CB console that I bought from Mobile Music in Richmond. I have no idea what brand it is though. Cost $20 and I like it because I can put the radio in and take it out real fast so I have the comfort of knowing it can't be stolen when the truck just sits there for long periods. The other mount you see is for my CB that wasn't in there when I took the picture.
Old 11-18-2009, 03:38 AM
torrespi's Avatar
Looks good 1 ... was wondering if your gonna try to tuck the wires and cable !
Salvadore Torres
WOSCT
Colorado
Old 11-18-2009, 10:08 AM
KG4INW's Avatar
Thanks. The wires and cable that you see in the pic is all that's visible and the CB covers it up pretty well. What's not visible is the split-loom tubing I used to protect the coax cables.
