Go Back   The RadioReference.com Forums > Topic Specific Forums > Radio Equipment Installation Forum
Radio Equipment Installation Forum Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 10-18-2009, 09:04 PM
paramedszaf's Avatar
Send a message via AIM to paramedszaf
Default Mini-UHF Tool
What size die is appropriate for the installation of a mini-UHF and what are the proper steps to install.
The twist on conectors do not give as good of connection as I can tell the difference in my mobile configuration.
If someone can point me in the right direction I would appreciate it!
Ed
HT-1250 VHF
HT-1550XLS VHF
CDM 1550 VHF (mobile install)
CDM 1250 UHF (mobile install)
Pro 1018
BCT 7
SC 150B
M1225 VHF x2
BC780XLT x4
BCT15 x2
And more to come!
Old 10-22-2009, 12:06 PM
OC05450R's Avatar
Are you talking about the crimping tool? If so just go to radio shack and purchase their professional crimp tool and it will tell you which size to use for certain connectors. -JOEYD
Radio:
Kenwood tk-8180k 30w 450-520mhz w/ KRK-10 remote mount kit
Maxrad 380-520mhz antenna nmo mount
Old 10-23-2009, 05:12 PM
You will need to get the crimper from Tessco or another Two Way radio equipment provider. Radio Shack will not have what you need. TESSCO-Wireless Network and Mobile Communications Products: Network Infrastructure, Mobile Devices & Accessories, Tools & Test Equipment
Old 10-23-2009, 10:36 PM
OC05450R's Avatar
you looking for a tool to do the box crimp on the sleeve?
Radio:
Old 10-24-2009, 12:59 PM
I am looking for the tool to crimp the pin and the sleeve on a standard 3 piece mini-UHF connector for VHF/UHF/800mHz applications.
HT-1250 VHF
HT-1550XLS VHF
Pro 1018
BCT 7
SC 150B
M1225 VHF x2
BC780XLT x4
BCT15 x2
And more to come!
Old 10-24-2009, 01:03 PM
nhiester's Avatar
Remember the crimper die size is based on the size of the wire you are using, as well as the connector.
Nathan
Old 10-25-2009, 12:10 PM
OC05450R's Avatar
as i said before if you go to radio shack and pick up their PROFESSIONAL CRIMP TOOL its $19.99 and it has the three sizes especially the smaller size for the pin and 2 other sizes for different sleeves-JOEYD
Radio:
Old 10-26-2009, 09:30 AM
Send a message via AIM to fineshot1
A simple search on the term "crimp tool" turns up many threads but see the one below that I point out a very good choice as a crimp tool for what you need. Its best to purchase the set with the tool and 2 dies
so that you can crimp a variety of crimp connectors.
Mini UHF Crimper
fineshot1
NJ USA
Old 10-26-2009, 05:03 PM
avtarsingh's Avatar
dont go to radio shack please... overpriced and junky crap is what they sell
i recommend paladin tools series 1300 style or something like that
something that is along those specs - so its 50-70 bucks? you only have to buy it once
Paladin Tools
dies are not that expensive
and to FINALLY answer your question
mini uhf for rg-8x you use .255 and .060
for rg-58 etc you use .213 and .068
easy way to do these (like bnc..tnc.sma etc ) is to slip ferrule over coax - cut back center cable just enough to crimp on center pin - make sure it holds - then strip the rest back using the connector as a guide - you usually want the insulation stripped back to where the knurled part of the connector changes to smooth (usually) and then slip ferrule up over shield and it creases the shield - trim the shield with scissors and then crimp ferrule - works great no measuring
as a general rule (if you dont know the actual size to use) - go bigger on the crimp hole
you can always go smaller and try another crimp - if its too big it wont affect it -
BUT if you go too small - you will break the pin(s) or crush the coax
special note - if you are going to crimp 9913 connectors - you need the die for it 9913 uses a .128 for center pin - as far as i know - a die like a rfa4005-02 or equiv has .100 .128 and .429 on it
Old 10-26-2009, 05:04 PM
avtarsingh's Avatar
also
Paladin Tools 1300 Series Crimper Crimp tool
Old 10-27-2009, 08:17 AM
Paladin Tools
I must agree with avtarsingh - DO NOT go to radio shack for crimp conn's or tools as they do sell
junk in this arena and Paladin is also a good choice. Whatever you do, do yourself a favor and purchase
a multiple die set along with the tool so you can do a variety of connectors - if you don't you will wind
up cursing yourself down the road when another type connector needs to be crimped.
PS - good info in your post avtarsingh - thanks
fineshot1
NJ USA
Old 10-27-2009, 06:21 PM
OC05450R's Avatar
im not saying dont get a better tool I am saying if you are not planning to use the tool alot then its not bad for $20 and to be honest with you it looks like the same tool as many other companies out there and your not getting raped. Its a CRIMP TOOOL!!!
Radio:
Old 11-01-2009, 03:14 PM
The RF Connection has a large selection of crimpers at a decent price: RF Connection Tooling
