Hi Everyone,
I want to thank everyone for the suggestions! I picked up all the parts on Sunday from Fry’s Electronics and put together the audio combiner using 70v transformers. The end result is MUCH better than I expected!
Here is a summary of what I put together.
-Input 1 Audio from TK-730 into 8ohm side of transformer #1.
-Input 2 Audio from TK-830 into 8ohm side of transformer #2.
-Output to Kenwood KES-4 speaker from 8 ohm side of transformer #3.
-70v side of all three transformers tied together.
Here are the transformers I used:
FRYS.com*|*MT2570
I mounted it all in a plastic project box also purchased from Frys. To make the audio inputs nice and neat on the box, I mounted 3.5 mm phono jacks for the inputs and output on the box. I have room in the box for one more transformer to make for a 3 input setup. I may try a third input in the future. With all my parts (three transformers, project box, and three phono jacks) it was just a little less than $30. It took about an hour of my time to superglue the transformers down, and solder all the connections.
Audio to the speaker is slightly quieter versus one radio to the speaker. I would say the volume from each radio is about 10-20% quieter. In my situation, this is not a problem as the audio from the TK’s are crazy loud.
There is no noticeable distortion running audio from two radios into one speaker. I am picky about audio quality, but I am not able to hear any distortion at my normal listening volume. I will try at different volumes over the next couple of days and let you know if there is anything noticeable.
My only complaint right now is that the transformers are a larger and heavier than I would like. In my situation, the box can be remotely hidden leaving only the radios and one speaker in sight so it is not that big of an issue.
Overall, I am VERY pleased with this solution, and I am very grateful for pointing me in the right direction. If you are looking for a way to connect two (or more) radios to one speaker, and are proficient with a soldering iron, I would definitely say to try this. It was easy to build, and much cheaper than other options I have seen. Thanks again for the great suggestion!
Best Regards,
Joe
