Go Back   The RadioReference.com Forums > Topic Specific Forums > Radio Equipment Installation Forum
Radio Equipment Installation Forum Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 11-01-2009, 11:41 PM
jfab's Avatar
Send a message via AIM to jfab Send a message via MSN to jfab Send a message via Yahoo to jfab
Thumbs up Powering Radios
Hey all-
I am planning on installing an RS Pro 197 in my 2002 CVPI soon, and I'm just wondering about power. I know most guys (who, unlike me, know what the heck they are doing) power it using the vehicle's battery, but I am too nervous to do that. Can I power the Pro 197 using a 12v plug in my car? If so, is it just "plug and play" or is there anything I should know? Any help is appreciated! Thanks
Old 11-02-2009, 10:35 AM
Default Radio Power
You should not have any problem using a 12v plug to power your equipment.
Old 11-02-2009, 11:52 AM
jfab's Avatar
Thank you! I figured, but wanted to ask the experts first! Just out if curiosity, how many scanners can you safely power with the 12v plug?
Old 11-02-2009, 11:56 AM
Default Amount of power
I would take a look at the fuse that is wired to the 12v outlet. Depending on your car it could be up to 20 amp circuit. As for how much to power, it depends what else is fed by the circuit and how many amps each radio draws. I would think you should be ok by drawing 10 amps or less for all the equipment plugged into the outlet.
Basically add up everything and if your below 10 you should not have a problem.
Old 11-07-2009, 02:41 AM
dracer777's Avatar
You should be able to safely power 3 or 4 on one fuse I would assume.
I run 3 DVD players, a radar detector, scanner, and cell charger off my parents mini-van.
_/\_"Smart" is understanding how ignorant you really are_/\_
Psalm 23:4 "Even though I walk through the Valley of the Shadow of Death, I will fear no evil, for You are with me...."
Old 11-07-2009, 07:32 AM
davidmc36's Avatar
My factory fuse is a 20 amp. I removed the wire to the outlet and installed a terminal block to power Sat. radio, 996T, 15T, 40 Watt audio amp, cell charger, two USB charging outlets, portable GPS power, and the draw measures around 9.5 amps with it all lit up. Of course every item has it's own fuse of the appropriate size for protection since the 20 amp factory fuse now just protectcs the line to the terminal block.
No Bounce, No Play.
The one who dies with the most toys wins!
Personal Weather Station
Old 11-07-2009, 02:51 PM
Default scanner power
I have a 03 CVPI and use the 12v power. Just remember that is hot all of the time. You will have to turn it off and on if leaving the car parked for a while
MikeOz
Old 11-08-2009, 01:32 PM
davidmc36's Avatar
Good point, you should make sure you don't leave a radio or something running for a very long time. All three of my factory outlets are switched off the key, that's why I added one off the battery buss for charging, but make sure how yours are wired up.
No Bounce, No Play.
