Help with 2011 Ford Explorer
foxtrot29
I'm in the planning stage of putting my Kenwood D710 in my 2011 Ford Explorer. Does anyone have ideas on how to run the power through the firewall or is there a decent power source inside the vehicle?
w2xq
Mentor
Burlington County, NJ
Dunno if the 2011 Explorer is the same layout as my 2006 Explorer, but I grabbed power for a 45w Yaesu FT-8800R dual bander from the fuse panel on the passenger side on the center console. There was an empty 20a-capable spot that did the trick. The power connection has been good for 98k miles so far. I never found a grommet to pass a power cable through the fire wall, and I knew if I drilled a hole I'd screw something up. The one downside of the fuse panel connection is that turning the ignition off also turns the radio off. No cross-banding capability unless I leave the key in the ignition... something I don't do. HTH.
CptCrunch
Winchester, Kentucky
Not that I found for my 2015 Explorer, I went to a car stereo installer to get a power wire run from the battery to the passenger compartment
