Go Back   The RadioReference.com Forums > Topic Specific Forums > Radio Equipment Installation Forum
Radio Equipment Installation Forum Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 01-12-2013, 5:54 AM
Question Scanner audio through vehicle speakers?
My 2009 Tucson has an auxiliary input jack. I was wondering if it is possible or advisable to hook up the audio audio output from a BC355N to that so it woud play through the speakers.
Dave
Dave
My Scanners: Uniden Bearcat BC355N, Uniden Bearcat BC125AT
Old 01-12-2013, 6:30 AM
Yes. You would need an audio jumper cable, of course. Look for a stereo or three circuit jumper. You should be able to find one at Wall Mart or most places that sell car radios.
Old 01-12-2013, 6:45 AM
I am dropping by Radidiot Shack this morning anyway. I will look for one there. Thanks!
Dave
Old 01-12-2013, 8:11 AM
mass-man's Avatar
You might look for a cable with at least one right angle plug! That way it does not stick out so far from either the back of the 355N or the aux jack on the dash. Just another thing, in either place, to get hit and or break!!!!
Cleve/W5CEM
Old 01-12-2013, 8:33 AM
evolocomotive's Avatar
Ive had my audio run thru my stereo for 5+ yrs and love it!
Old 01-12-2013, 11:12 AM
Only negative is that it ties up your AM-FM radio ( having to put it on the AUX setting) I like to listen to both, otherwise it's great.
Old 01-12-2013, 11:31 AM
Ensnared's Avatar
Default Mono Vs Stereo
In my opinion, I get more volume by using a mono cable. Mine comes out the left side where I can hear. If I use stereo, it is not as loud. I even have a high power JBL amp in my car. It really sounds good.
"If you gave [Jerry] Falwell an enema he could be buried in a matchbox." Christopher Hitchens
Old 01-12-2013, 11:48 AM
Way back when, I had a '71 Chevy Nova. Since I had put in a custom stereo and speakers, I had connected my old Regency 10 channel crystal based scanner (stylin' at the time...) into the factory dashboard speaker.
But like Kennyloatman said, if you use the AUX jack, you lose all your other audio. Get a good/cheap Motorola speaker and keep it separate.
Old 01-12-2013, 1:10 PM
The aux input jack in the car is probably stereo. That means that the tip and ring are the left and right channels and the barrel of the plug/jack is the common. If your scanner has a mono output you wire the mono output to the tip and ring, and the common of the scanner output to common of the plug you're going to plug into the aux input. By doing so you should get scanner audio from both sides of your car's system. It's also quite possible that store such as RS will have this type cable available pre-made and all you then have to do is plug it in.
Old 01-12-2013, 4:12 PM
That is how mine works and Radio Shack did have the ready to go cable.
Old 01-12-2013, 9:04 PM
Can't speak for Uniden but GRE's PSR-800 uses a stereo jack on the scanner. So a standard stereo jumper works great with my 800.
Old 01-13-2013, 6:27 AM
I'm an idiot. I completely forgot to pick one up when I stopped in. I had a million things to do and places to be and just plain forgot. On the plus side, I have one at work that I can try for a day or two to see if I like it. It's probably only mono, but it will give me an idea. I am also considering a separate speaker, so that will help me decide without spending any $.
Dave
Dave
Old 01-14-2013, 11:29 AM
I tried it on lunch using a mono audio cable from work and it did work. Still not sure if I could do without the radio. Probably opt for an external speaker instead.
Dave
Old 01-17-2013, 7:39 AM
GrumpyGuard's Avatar
I have my 106 in a homemade cup holder stand with a small 2" radio shack speaker attached to the stand. I did the speaker mod using a jumper wire from the base of the antenna to the speaker jack and this works very well.
Old 01-17-2013, 8:19 AM
AC0RV's Avatar
Send a message via Yahoo to AC0RV Send a message via Skype™ to AC0RV
Smile
I am using a wireless fm transmitter from Walmart to supply the audio the vans radio. Its to be working great.
May the LORD watch over you and your Family.
David F AC0RV
Skywarn # M187201
Old 01-21-2013, 9:30 PM
Default Easy Solution
My suggestion is you go buy a 2009 or newer Dodge Charger Police. There is an input on the police interface for audio that will play the scanner audio over the factory speakers, muting the radio/cd when there's scanner traffic, and playing the radio/cd when there's not.
Old 01-21-2013, 11:50 PM
Best option to date, or see if you can put an interface together.
