A little background info on this project... I volunteer at my local EMS Station and we are putting a scanner in the day room/lounge. We have a radio/repeater combo in the room now, but we switched to a new dispatch channel, and a new tower was put up in our coverage area. Leaving that only able to monitor Med 9, and with the new channel and tower, the repeater part is no longer used. I'm donating them a BC 340 CRS so that we can monitor the new dispatch channel plus the surrounding county channels. The current coax cable is hooked up to the Motorola radio/repeater. My plan is to get a Motorola to BNC connector at my local Radioshack and use the existing cable. We are also buying an all band outdoor antenna ( SP800BNC, SPIDER BASE SCANNER ANTENNA 25-1300 MHz FULL FREQUENCY COVERAGE, ANALOG OR DIGITAL with cable and BNC connector - Scanner World - The Largest Dealer of Scanning Radios in the World) to put outside on the existing repeater tower outside our station.We want to have many speakers in the building in different rooms run off of this one scanner. Two Questions? What is the best method to do this? and can you use any speaker if you have the right jack?
