Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Radio Equipment Installation Forum
Radio Equipment Installation Forum - Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 06-24-2014, 4:30 PM
W3AWF's Avatar
Default 1993 Jeep Wrangler Install
Okay, I have going to the extent of what I can do with this and figured I would post it here to see what you all have to say. I have a 1993 Jeep Wrangler YJ 2.5l, I have a scanner and 80 and a 2 meter rig in it. I've had the same radio and scanner in all three vehicles I've ever owned, and never had a problem with alternator noise until now. When the vehicle is off, it's the clearest radio I've ever heard, as soon as I start the jeep I get a little bit of wine from the radio, once I start driving it's almost unbearable. I've tried everything that I can think of including talking to good friends of mine to do installs for a living. I currently have a DC filter in line in the cab, I originally had it in the engine compartment and was told that it was too close to the alternator so I moved it to the inside today, still no help. I have clean power and wired it right to the battery. I've tried everything I can think of and can't figure this one out. The other thing that I figured out is that when I have my high band portable in the vehicle receiving, I still get the same whine as I do on the mobile. Does anyone have a solution to this problem? I originally was leaning towards it being alternator wine or the electrical system, but now I believe I am getting it through the antenna. I don't know how old the alternator is, it might be the original one. I know that when the alternator generates electricity it is originally AC and it is then rectified to DC. My question is, if the rectifier is starting to go bad will it cause extreme alternator noise to be received through the antenna?
Old 06-24-2014, 5:35 PM
n9mxq's Avatar
Is the 2.5 fuel injected in that year? My 97 TJ had horrendous injector noise. Bad enough to where it made the trail radio (CB) all but useless, but never noticed it on the dual band rig that was installed.
Gene
Transceivers, receivers, and SDR! Oh My!
Old 06-24-2014, 6:56 PM
I had a 93 - but it was a 4.0. I have no HF hear but had a 2 m and scanners. I do not remember anything that caused issues.
If you think it's via the antenna you should be able to get it with a hand held standing close by. You could also try powering via an external battery.
I've often seen alt. whine in the audio circuit. I used to have some choke/filters etc. that worked, but it's been years. Plus they never would have handled over 10 amps DC. Might find some at one of the high end car audio shops.
I'm assuming you also have it grounded at the battery. Try a choke on the neg. also. In fact sometimes it takes several chokes inline
'luck de N8PFF
BCD536,Hp2(e),HP-1(e)x2, BC780, BCD996t ,BCD996P2, BCD325P2, Pro 2005, 2006(x2), Pro34,VR500,AT803,R5000and other RF capture devices
Old 06-25-2014, 12:10 AM
W3AWF's Avatar
Yes it is fuel injected. And yes I went right to the battery with the positive and negative, I haven't tried another filter on the negative side, guess i'll try that next.
Old 06-25-2014, 5:02 AM
popnokick's Avatar
Disconnect the antenna from the radio and turn on the radio and start the engine. Noise gone? Then it's coming in through the antenna not the 12VDC lines... and is prob not alternator whine. If noise is still there at same intensity, you know it IS on the 12V supply.
Old 06-25-2014, 6:16 AM
krokus's Avatar
My YJ was not a direct ground between the block and the body, there was a resistor. Something about that sounds wrong to me, but the engineers must have had a reason.
Check to make sure your ground lines are clean.
Sent via Tapatalk
Old 06-25-2014, 8:52 AM
Well, there is one problem. Take the ground off the battery and attach it to a proper chassis ground. That should help the noise a little bit and the added bonus of not cooking your radio when some other ground fails.
Old 06-25-2014, 12:52 PM
W3AWF's Avatar
So this morning I started the Jeep and connected my mulitmeter to the battery. At the battery I had 14.20V. I then moved the negative probe to the alternator case, and had the same reading. So I then moved the negative to the engine block, and had a good ground there. Finally, I moved the ground of the meter to the tub "body" and....... nothing. I had a bad body to chassis ground! So I took some 2 gauge battery cable I had laying around wire wheeled both the point on the tub and the frame down to bear metal and made a new body to chassis ground..... and the noise is still present! This is driving me crazy! I've tried everything I can think of.
Old 06-25-2014, 12:54 PM
W3AWF's Avatar
I will try that right now actually, this is all i've done today and its my day off.
Old 06-25-2014, 12:58 PM
You may have a bad diode(s) in the alternator. Try this: Put your meter on the AC function and measure across your battery. You should measure less than one volt. If it is more then you may have a bad diode(s).
BB
Old 06-25-2014, 1:09 PM
W3AWF's Avatar
The noise only happens when I key up on a repeater, and unkey you get a major amount of the noise. It only ever happens on receive, I get perfect signal reports when I key up and talk but receive is very noisy. If I turn the squelch down with the antenna hooked up the noise is not present. I unhooked the antenna from the radio and turned the squelch down and the noise was not present again.
Old 06-25-2014, 1:13 PM
W3AWF's Avatar
BB
Just did it, I have .041V AC across the battery.
Old 06-26-2014, 4:29 AM
krokus's Avatar
Just to clarify: The noise is not present until after you transmit?
Sent via Tapatalk
Old 06-26-2014, 5:11 PM
Sounds like a ground issue, check everything and I mean everything antenna ground,cables coax the whole shabang.
Old 06-26-2014, 5:37 PM
That's why you fuse both the ground and positive. Very common way to install.
Old 06-26-2014, 6:08 PM
shielded spark plug wires and new plugs. YMMV.
Old 07-03-2014, 11:53 AM
W3AWF's Avatar
We have narrowed it down to what we believe is ignition noise. The whole ignition system was replaced accept for the cap and rotor in March. I believe the noise is coming from the cap and rotor, it is probably very old, being that the previous owners never did preventive maintenance, the wires were the original wires! So i'm off to autozone to go buy a cap and rotor.
