2014 F150 ideas
ts548
I need ideas on how to remote mount 3 xtl radios.
Yeah, mount them in the center console. Not sure if they make one for the 2014's yet, but it's worth a look. It's an frame that goes under the lid. The radio heads get mounted on a plate and the plate gets mounted to the frame. Look at the Havis and Troy websites. Probably someone more familiar with doing radio console mounts can come up with the right part numbers.
Now, how about the antennas. Last I heard the 2014's have aluminum body, right? That's good, since magnets belong on refrigerators, not antennas.
com501
The aluminum may be a problem. I would certainly very cautiously inspect the gauge of the metal before drilling lots of holes, a standard NMO is gauged for steel sheet metal. Aluminum may be a tad thicker than you expect.
I know for previous years, fleet Fords had a gearshift relocation kit that put the floor mount back on the column. Then a standard full rail console would fit.
Not sure how much you want to hack at a new vehicle.
That's a very good point.
Since a lot of these see utility, government and public safety use, I'll be interested to see how the installs go on these.
Magnetic mounts certainly have their place, but glad it won't be on the roof of these nice looking new trucks.
ofd8001
Louisville, KY
The piece that says "Synce" just below the climate controls can be removed and a control head may fit there depending on size. I stuck a remote head for my 996XT scanner in that location.
For antennas, I'd suggest vehicle specific mounts. The antenna farm has them. While mine is a 2013, I suspect the same bracket may work unless there has been a major re-style:
There is a photo of my antennas on another post in this forum.
