Any Ford Fusion Installs?
GSPD
I've got a friend who asked for some assistance with an install in his new Ford Fusion. Anybody run a line through the firewall? The install will just consist of one ham radio and planning to power it from the battery. Pictures and info would be appreciated.
EricCottrell
Boston, Ma
Hello,
There are several threads on here dealing with the Ford Fusion. Anything dealing with 2013 and later is the same as a new Fusion.
http://forums.radioreference.com/pi...setup/263343-ford-fusion-install-finally.html
http://forums.radioreference.com/pictures-your-shack-mobile-setup/304727-2012-ford-fusion.html
http://forums.radioreference.com/pi...tup/289253-2013-ford-fusion-rs-pro-160-a.html
There is a plug in the firewall that can be used to get the wire to the battery. It may not be accessible in later years.
How to get amp wire through firewall to battery? - Audio, Navigation & SYNC - Ford Fusion Forum
This talks about an alternate.
Power Cable/Firewall - Audio, Navigation & SYNC - Ford Fusion Forum
73 Eric
GSPD
Thanks Eric...I did find those same links during a search and thought maybe I might find something new.
n1xh
Spencer, MA
n1xh
Spencer, MA
Drivers side grommet behind and above break pedal will get you under the hood
