Looking for recommendation(s) for a directonal beam antenna
comoman
I realize I will probably get all kinds of suggestions but I had rather have a recommendation for a 11 meter directional Yagi antenna from an amateur radio operator here. Not that CB operators don't know anything. It just that I think I will get a more clearly defined reason and recommendation for a directional Yagi antenna from someone that has had more experience.
I am considering a Yagi directional bean antenna in the 5 to 6 element size range. I've tried several beam antennas and seem to get a lot of false information from advertisers instead of more realistic data. I will have the antenna approximately 68 feet from the ground to the boom and don't mind spending the money as long as the antenna performs as advertised. I do understand how to build and set an antenna so I'm not looking for all of the if, and or buts about antenna, just real world performance data from an experienced user.
I'm leaning more towards something like a 11 meter 6 element Long-John. I'm mostly interested in which antenna has the best real world gain.
Your experienced input will be appreciated.
1MO-Bob
Check out M2 and Mosley two of the best for what you ask about.
Bob
KD8NIV
West Virginia
I'd go with a Maco beam.....
But if money isn't a problem, think I saw on facebook awhile back that BM Technology builds a beam now, and uses a different design for the gamma match....
comoman
Can't seem to find anything on BM Technology directional beam antennas.
K5MPH
Brownsville Texas,On The Border By The Sea.
I have used a Maco beam (3 element) in my CB days but for ham radio i like the Mosley antennas they are built very well i have an ham friend that has an 4 element for HF and does very well on the ham bands good luck......
KD8NIV
West Virginia
Have a friend in Md who runs a Mosley 3 element beam and he talks all over the place, not using a amplifier just a 100 watt radio....
comoman
Unfortunately we can't do that legally on 11 meters. You friend is most likely a HAM, right?
KD8NIV
West Virginia
Yes, my friend is a Ham operator, and uses his stuff on the HF bands.....he also has radios for 11m, but don't think he uses it..
