Delivers1234
So, I am not sure what type of fuse block to get and wire and switch.
I have a yaseu ftm-100, bearcat 980, and a driving cam (uses cigeratte lighter).
the fuses are 6 amps max. the yaesu has fuses on the black and red wires. i looked on ham radio and found MFJ MFJ-1104 DC Power Panels
http://www.hamradio.com/images_manuf/H0-013876A.jpg
I also looked at the 4 block anderson pole block. The block would be secured on the floor behind the main console. I'd like to run the negative and positive leads from the battery to the equipment. The fuse blocks i've seen only have a positive lead.
Wire size?
Type of fuse block with cover?
How do i connect the negative leads from the equipment to the battery lead?
Thank you.
Wire size?
Thank you.
