Sirius Satellite radio antenna:how close to 2m antenna 65w output??
FKimble
Newnan, GA
Wife just got herself a new CR-V and wants me to hurry up an get her 2m rig installed. Beside being like most new vehicles with no place to put a radio, it has a "moon" roof which sides back. Looks like there may be just enough room for the NMO behind the sliding glass. But there is a Sirius Satellite radio antenna at the rear edge of the roof. Is it safe to have it real close to a transmitting antenna on 2m? Rear tailgate opens too far to mount a gutter type on the hatch, it would bend the antenna on the roof. So any advice for an NMO mount or a different type?
Frank KK4YTM
bharvey2
Frank KK4YTM
We bought the wife a Ford Edge last year and the entire roof is glass. (Although only part of it opens) This posed a problem for antenna mounting. I ended up going with a Diamond NR 770B antenna mounted to an articulating mount clamped on to the edge of the rear hatch. I had to find the proper location so that the hatch would open without damaging the antenna. This Diamond model, being a 1/2 - 5/8 wave helped given that the ground plane was compromised. Not the perfect solution but better than mounting it in the center of the hood.
KK4JUG
GA
Before you buy an "edge" type mount, double-check that the vehicle will take it. In some vehicles now, the inner metal goes straight to the edge and there's no "lip" for the antenna mount.
mrweather
On my last car I had a UHF antenna on a permanent NMO mount that was 6" from the XM antenna. I had no issues.
