Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Radio Equipment Installation Forum
Radio Equipment Installation Forum - Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 05-03-2018, 10:53 AM
ladn's Avatar
Default Antenna Install 2018 4Runner
I just got a 2018 Toyota 4Runner and need to install 3-NMO antenna mounts on the roof with cable runs to the underdash or console area.
Considering the vehicle is loaded with side curtain air bags, I don't really want to install the mounts and run the cables myself.
Any recommendations for a reliable and competent shop in the San Fernando Valley area of Los Angeles?
I can handle the install of the actual radios (2 transceivers and a scanner), but I am looking for the factory literature that shows where the wiring runs and where I can safely tap 12v for ignition/acc sens as well as any RFI mitigation issues to be aware of.
Thanks in advance.
Old 05-03-2018, 11:45 AM
thats a nice vehicle..iv got a highlander and only have just enough space for a cup holder to put my HH....i cant imagine running that much radio stuff.....pics after install please
scanning the pinelands of south jersey bcd436hp pro651 pro652 pro2006 pro2096 bct15 grundig satellit 800
Old 05-03-2018, 11:47 AM
I think you would have better luck asking that question in the San Fernando Valley area of Los Angeles forum thread.
https://forums.radioreference.com/gr...as-discussion/
Just sayin'...
FT-2900R, FT-101EE, HTX-202, IIC-2AT, BTX-121, UV-5R, KT-7900D
Old 05-03-2018, 2:39 PM
ladn's Avatar
I have the same number of radios in my 2001 4Runner. I (reluctantly) used mag antenna mounts because that vehicle has a moon roof. The radios installed fairly easily. The remote head 2m/4440 radio went on the console, forward of the shifter (with the radio box under the driver seat). The CB went below the dash to the right of the steering wheel, The handheld scanner was mounted on a cell phone mount affixed to the ash tray.
The biggest issue with the 2018 for the radios is that now there is an air bag below the dash. It looks like there will be adequate room somewhere on the console for the control head of the split mount radio and I'm still not sure about the scanner.
ladn's Avatar
Will do, thanks.
Old 05-04-2018, 11:31 AM
norcalscan's Avatar
I've got a new model Highlander (without moon/sun roof) and drilled the holes and did some remote head installs up front. I'll post pics here when I get a moment.
What I did was pay $15 for 2 days of access to Toyota's Tech Info System. Look for the Standard tier, 2 day access for $15. Once there, you'll have access to the entire manuals in PDF form for body, engine, electrical etc. For 2 days I didn't sleep and I downloaded everything I could think of for my Highlander that I could possible ever use as a non-mechanic tweaking my vehicle. I focused on removal guides for the entire interior, headliners, NAV/Stereo wiring guide, entire electrical schematics and diagrams, ground points, airbag systems, etc. I reference the downloaded interior panel removal guides often when working inside. Tells you every clip location and type, etc. Also allowed me to route wires away from RFI sources, find ign sense etc.
I can drill an NMO into a new vehicle without hesitation (measured center 5 times haha) but I chickened out on removing the headliner (intensive process with how it's installed), so my two NMO mounts are front and back where I could access the coax from behind the (removed) dash light console, and in the back near the Sirius antenna and accessed by peeling back the tailgate weatherstripping and headliner edge down a hair enough to get an extendible hook in there and snag the coax.
Front coax routes straight to the front dash light console and then follows the windshield seam over to the A pillar. If you run your finger along the edge of the windshield and headliner you'll feel the space I'm talking about. I removed the A pillar cover and routed and secured the coax down behind and out of the way of the airbag. The rear coax goes back to the C pillar (no airbag) and down, then hidden behind body panels until finally revealing under my drivers seat. If I could get the headliner down and B pillar panels off, I'd do a third NMO to keep scanner, commercial, and ham separate but my ham is unfortunately secondary on a part 90 radio. Not sure I could get a 3rd radio up front anyway, stupid modern dashboards.
Airbags are scary unless you understand and respect them. Remove the negative on the battery before working near them. Never work around them blindly, you want to see the whole picture so you don't inadvertently block their path. Visualize the entire deployment path and keep your coax away from that path. The bag wants to inflate in a certain direction, AND any body panels in the way are designed to break away, so don't secure coax to any mechanism that is meant to break away, or would be in front of the bag deployment.
Good luck!
Old 05-04-2018, 11:50 AM
I've got two NMO mounts in the roof on my 2016. (Shack photos) I ran the coax along the factory wiring harness, so that it isn't in the way of the curtain airbags.
Old 05-04-2018, 2:51 PM
cmdrwill's Avatar
And most of the time you do not have to remove the headliner. Just the rubber strip at the top of the back door and you can fish the coax down there easily. Then down the back post.
Old 05-07-2018, 9:34 AM
ladn's Avatar
Thanks to all for the feedback.I also have a request in to Toyota to locate the radio installer literature.
Next comes the matter of installing the actual radios. The Icom 2730 should be easy since the radio chasis will go under a seat and the control head will (probably) go on the console ahead of of the shift lever and below the USB and 12v ports. The potential location of the 10M radio is another question entirely since both the driver and passenger side have air bags below the instrument panel. It's enormously frustrating that radios like the Anytone AT-6666 are not available in a split mount design.
I always power my radios directly from the battery and use a heavy duty relay to control the circuit. This lets me have the radios on with ignition sens, always off or always on. Setting this up is probably the least of the challenges, but accessing the lower dash switch plate (there are a couple of unused switch knock outs) is another matter.
Tags
4runner, installation, nmo install, toyota
