Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Radio Equipment Installation Forum
Radio Equipment Installation Forum - Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 07-04-2018, 9:29 PM
Default Solid Coax in Vehicles
Is solid coax OK to use in a mobile application? Laird makes the MB8X mount which has RG8X solid coax which I think I'm going to use for all my installs moving forward. I know solid primary wire is a no-no in mobile applications but I'm not sure if coax will fatigue?
Motorola HT 1000, XTS 3000, CDM 1250, APX 4000
Kenwood TK-250G, TK-2180, TK-790
Uniden BCD996P2 x2, BCT15X x3
Old 07-04-2018, 9:37 PM
Solid center coax is perfectly fine for mobile installs. Depending on the desired band, it is really the only option as stranded center would have to much loss.
I use the MB8X for all my personal vehicles, never a problem.
Solid wire in the 12 volt world has to do with connection issues. Example: you can't butt splice a solid wire without fear of it loosening and causing a problem, or any crimp connector. That's why you never see a crimp connector in house wiring. Also, solid wire is not flexible enough.
Old 07-05-2018, 12:25 AM
mmckenna's Avatar
I've used LMR-240 (bought the mount by accident).
It worked fine. It was a bit stiffer than the stranded center conductor, and you'll need to be a bit more careful when you route the cable.
Old 07-05-2018, 7:39 AM
mcscanner's Avatar
Are you sure its solid coax. If labeled RG8X none of the quick Google searches I did spec it as solid. I use it in my shack and it stranded too. I'm not saying its bad, just pointing out a possible difference in name vs. material.
The road goes on forever and the party never ends...
Old 07-05-2018, 8:10 AM
Their cut sheet says it's solid. They don't seem to offer a mount with stranded RG8X.
https://assets.lairdtech.com/home/br...ounts_0414.pdf
Old 07-05-2018, 10:40 AM
W9BU's Avatar
Lead Wiki Manager
I've never been a fan of solid center conductor cable in mobile installations. I worry, possibly without foundation, about the vehicle's vibration work hardening the center conductor resulting in breakage.
Larsen used to offer a double shielded RG58-type cable on their mounts that I thought was worth the expense. But, I don't see it in the cut sheet you provided.
If you are worried about the different in loss between R8X and RG58, I think it is not worth worrying about in the cable lengths you find in most mobile installations.
Lead Wiki Manager and Forum Moderator.
"The whole world's living in a digital dream. It's not really there, it's all on the screen." -- WB6ACU
Old 07-06-2018, 10:46 AM
How hard is it to attach your own coax to a NMO mount? Is there a guide anywhere?
Old 07-06-2018, 11:37 AM
mmckenna's Avatar
Depends on the mount. The basic ones are just a solder connection. Center conductor is soldered, and the outer shield has tabs that bend around and soldered.
The -HF mounts have a soldered center conductor and a crimped shield.
Easy enough to solder your own NMO mount, even if you don't have a crimp tool. You can buy "bare" NMO mounts, or just salvage and old one.
Old 07-07-2018, 11:25 AM
I've experienced a broken solid centre conductor cable in my car installation. Never had any issues with stranded. And given the shorter length of cable used in most (all?) mobile applications I wouldn't expect much of difference in performance between solid and stranded.
Old 07-08-2018, 11:30 AM
Solid center confuctor RG58 has been the industry standard for many decades and is used on virtually ever mobile installation so no, not a problem at all.
Old 07-08-2018, 12:22 PM
Everything nowadays coax wise is pretty much solid center in a vehicle. All your modem antenna's, WiFi, cellular, radio, etc have some sort of solid center coax. Usually high frequency mounts use a LMR-195 type cable, buy same physical size as RG58.
A problem with solid center is improper coax installation. If done with a knife, care must be taken NOT to score the center conductor, or you will have problems. Otherwise, I've never had a problem.
Old 07-08-2018, 1:32 PM
mmckenna's Avatar
Proper strain relief, routing, securing, etc. prevents most issues. If coax center conductor is breaking due to movement or vibration, then that's a separate issue.
If you are using a mobile antenna with a portable radio in a vehicle, then making sure you have a stranded center conductor would be a good idea.
Old 07-09-2018, 7:36 AM
Is there a special tool used to crimp the NMO mount to the braid?
Old 07-09-2018, 8:51 AM
mmckenna's Avatar
On the NMO-HF's, I'm not sure, but I do believe a standard RG-58 crimper would work.
