Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Radio Equipment Installation Forum
Radio Equipment Installation Forum - Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 08-06-2018, 10:38 PM
5stormchasers's Avatar
Default Firefighter/EMR response car
This thread is for my pov. I am a certified Level 2 firefighter as well as a certified First Responder. Changing vehicles from my 2006 Tacoma to either an 08 Nissan Altima or an 08 Chevy Impala. I wanted to start this thread to get some input first. I am open for ideas, comments, and criticisms. I have a SoundOff NForce dual dash light red/white, 2 Whelen Ions in red, a Vertex Standard VHF mobile radio with antenna, and a red rear deck bar for traffic direction. I am going to be purchasing some Feniex Cannon hideaway leds split red/white, and 2 NightHawk red/white running board lights. I chose the Cannons over the Whelen Vertexes because the Cannons can double as a reverse light. I would like to wire all my lights to a single control head......the Feniex 4200 mini, which I have attached a pic of. Have any of you guys ever used the 4200 mini? If so did you like it?
Old 08-06-2018, 10:47 PM
Iíve used the 4200 to active LED spot/work lights. Love it. I also like the wig-wag patterns it has but Iíve never used them ďon the streetsĒ.
Sent from my iPhone using Tapatalk Pro
Old 08-06-2018, 11:05 PM
Awesome. I like how everything can wire directly to the control head also the buttons can be programmed for lots of different things. I doubt I will use the wig-wag function. I will more than likely just have them all for powering the lights. I will select the patterns on the lights and leave them.
Old 08-07-2018, 3:10 AM
krokus's Avatar
What is a "Level 2" firefighter?
Sent using Tapatalk
Old 08-07-2018, 11:55 AM
It's a certification course through the state. It is a certified firefighter 2.
Old 08-07-2018, 7:44 PM
Level 2 here also. Good luck with your install!
Kevin
Old 08-08-2018, 5:23 AM
krokus's Avatar
So your state has a different term for FF2, got it.
Sent using Tapatalk
Old 08-08-2018, 5:41 AM
krokus's Avatar
I'm not sure if your state allows it, but I would suggest no rear facing white lights. They are very distracting, and/or blinding to drivers.
Sent using Tapatalk
Old 08-09-2018, 12:06 AM
We have FF1 and FF2. I've taken both. Very good info in those classes.
And yes we are allowed to have white to the rear. Most response vehicles have some sort of hideaway strobes or white led kits in the rear.
Old 08-09-2018, 9:59 PM
I wish California allowed them on POV (with proper permissions of course).
Tags
emr, firefighter, pov
