Go Back   The RadioReference.com Forums > Topic Specific Forums > Radio Equipment Installation Forum
Radio Equipment Installation Forum Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 08-13-2007, 6:42 PM
Send a message via AIM to ECGBaritoneMastr
Exclamation 1996 Toyota Camry Install
So I recently bought a 1996 Toyota Camry LE, and it has an after market stereo in it. it appears as though the original Toyota radio was a double din, and now there's a space with some type of storage flap that you can open and put things in, IE change, wallet. I'm planning on installing a Uniden BCD996T semi-permanently (I'll probably sell the car next year, and the scanner isn't gonna go with it, of course). I haven't gotten the 996T yet, but it should be here in about a week so I can do i size comparison. Anyways, anyone done an install like this before? Thanks!
RS Pro-95, RS Pro-528, BCD996T
Old 08-13-2007, 10:25 PM
I've got a 96 LE and yes, the compartment will come out and you can mount a single DIN radio in its place (996)
Old 08-14-2007, 6:11 PM
thanks. do have any pictures of it or instructions for installing it? my question now is how to remove the storage area below the stereo. here's a picture i found on ebay. http://photos2.ebizautos.com/3697/2032158_14.jpg
Old 08-14-2007, 10:12 PM
been a while since I swapped out the factory stereo for a nice Kenwood. I believe the factory radio and storage compartment come out together.
Old 08-15-2007, 3:01 PM
The trim ring around the stereo/pocket needs to come out first (the panel with the cig lighter). Pull it from the bottom right corner, it will pop out.
There will be 4 bolts holding in the stereo/pocket assembly bracket. Once those 4 bolts are removed the entire assembly can be pulled from the dash, and the pocket can be removed from the bracket.
You can then ISO mount your scanner to the bracket, and reinstall.
Pics from a pro2066 install are shown below.
Old 08-15-2007, 5:17 PM
okay thanks! and i find it funny that we both have the same JVC stereo. haha. does it matter if it stays on top or not? I think I want the scanner closer to me.
Old 08-15-2007, 6:07 PM
There shouldn't be any problems swapping the order of the units.
Old 08-26-2007, 12:16 PM
done! http://www.radioreference.com/forums...ad.php?t=79521
Old 08-26-2007, 12:33 PM
N4JNW's Avatar
Send a message via AIM to N4JNW Send a message via MSN to N4JNW Send a message via Yahoo to N4JNW
That has got to be one of the most clean and professional mobile installs I've ever seen.. It looks factory..
Very well done!
Realistic Pro-57 (10 channel workhorse)
GRE PSR-500
Old 08-26-2007, 1:43 PM
[QUOTE=RocketNJ]and you can mount a single DIN radio in its place (996)[/QUOT
OK, I confess...I have no idea what a "DIN" is. Who wants to educate me.
Old 08-27-2007, 8:33 PM
Very well done!
dremels tools work well. thanks!
