Last week I bought a new computer with Windows VISTA Home Premimum Edition and having the problems with installing and using the radio shack USB serial port adapter. I did some researching and found a work around on the install of the drivers and it worked. So I am sharing the information to all those who have or will have this problem;
Model: 26-183 | Catalog #: 26-183
Here's how to get the out-of-box cable to work with Vista:
-Do not plug cable into USB yet
-Go to Start->Help, and search for "compatibility wizard"
-Select "What is program compatibility"
-Select "Click to open program compatibility wizard"
-At welcome screen click Next
-Insert the CD/DVD that came with the cable, but do NOT plug cable yet
-Shut down any autorun option should you see it
-Ignore any Explorer windows referring to the Radioshack USB Serial Driver, and close them
-Get back to the compatibility wizard
-Select "I want to locate program manually" and click NEXT
-Click Browse and navigate to the drive containing the Radioshack driver CD/DVD
-Select the program on the CD/DVD, click Next
-Select the needed level of compatibility
---I had it running previously on XP SP2, so I selected that
-Slog thru the Vista dire warnings and Vista will
install the driver correctly
-Restart your computer when advised
-NOW, Plug in the USB cable with attached device --Vista will detect the USB device, complete the driver installation, and your device should work.
I take no credit except for finding this information from the radio shack website and sharing it.
P.s. I tried the wizard for installing a program and it worked fine except for the new BETA version of Unitrunker which has no install.
