| Radio Shack Scanners A forum for the discussion of all Radio Shack scanning radios and receivers. |
06-11-2008, 08:34 AM
Windows VISTA and radio shack serial port adapter vista install
Last week I bought a new computer with Windows VISTA Home Premimum Edition and having the problems with installing and using the radio shack USB serial port adapter. I did some researching and found a work around on the install of the drivers and it worked. So I am sharing the information to all those who have or will have this problem;
Model: 26-183 | Catalog #: 26-183
Here's how to get the out-of-box cable to work with Vista:
-Do not plug cable into USB yet
-Go to Start->Help, and search for "compatibility wizard"
-Select "What is program compatibility"
-Select "Click to open program compatibility wizard"
-At welcome screen click Next
-Insert the CD/DVD that came with the cable, but do NOT plug cable yet
-Shut down any autorun option should you see it
-Ignore any Explorer windows referring to the Radioshack USB Serial Driver, and close them
-Get back to the compatibility wizard
-Select "I want to locate program manually" and click NEXT
-Click Browse and navigate to the drive containing the Radioshack driver CD/DVD
-Select the program on the CD/DVD, click Next
-Select the needed level of compatibility
---I had it running previously on XP SP2, so I selected that
-Slog thru the Vista dire warnings and Vista will
install the driver correctly
-Restart your computer when advised
-NOW, Plug in the USB cable with attached device --Vista will detect the USB device, complete the driver installation, and your device should work.
I take no credit except for finding this information from the radio shack website and sharing it.
P.s. I tried the wizard for installing a program and it worked fine except for the new BETA version of Unitrunker which has no install.
Glenn
kd5dga
Nolanville,Tx.
Pro2052
Icom PCR1000
Pro433
PRO2055
06-12-2008, 10:36 AM
Moderator
You can also follow the advice given by Kevin in this post about drivers for the subject cable.
Also, moving this to the RS forum.
01-03-2009, 09:28 PM
NOT! No 64-bit support....
NOTE:
THis does not work for Windows Vista 64-Bit. Most of the posters are unaware that there are two significant versions for Vista - 32-bit and 64-bit. Please specify which when posting!
Still looking for solutions to the Vista 64 Bit USB-Serial driveer issue.....I think dual boot may be it.
intermod
01-03-2009, 09:44 PM
64 bit Vista
I had no problems with driver intall. Vista found drivers in the 64 bit file,loaded them and then went to the internet ,found and installed updates.Vista is a new animal for me and I was suprised at how well it performed.Using ARC 500 software I had the unit up and running in short order!
Ralph
01-03-2009, 09:50 PM
Can't get it to work either...
I cannot get it to work with my Vista either... I just do it with my other computer and it works there. Something with the drivers but have not had time to play with it... Good Luck!!!
Thanks, - Eric
01-03-2009, 10:29 PM
Thanks, - Eric
If you need drivers for the 20-047 programming cable, they're here:
http://www.ftdichip.com/FTDrivers.htm
01-03-2009, 10:30 PM
Ok thanks I have them but it was not letting me upload to the scanner... I will try again and troubleshoot when I get time.
01-03-2009, 10:37 PM
check the comports
01-03-2009, 10:38 PM
Originally Posted by AlabamaRS
check the comports
I have got that set to COM 3
01-23-2009, 04:36 PM
Anyone know how to get it to work on Windows 7? =]
@Juss10 (Follow Me)
@OlyScanner (Live scanner updates blog)
Pro-97
Thurston County, Wa
01-24-2009, 12:28 AM
Without hijacking this and digressing to a wasteland-esque rant.... It worked fine in Win 7 when I upgraded Vista to 7. No problems with any of the software I use that is radio-related (quite a bit of it, too.)
Since Windows 7 has no liking to my Trend Micro antivirus, and for some reason my normally speedy laptop pretty much ground to a halt, I decided to do a clean install. BAD idea. Nothing, and I mean nothing, that I needed to run would install. I assume it is due to the installers not liking the Windows version when it checked the system... Result is I reinstalled Vista 64 and I am back in business.
So, the RS USB cable worked fine for me with the Vista -> Win7 upgrade. NOT when Win7 was clean installed.
-- Kevin
01-24-2009, 02:58 AM
-- Kevin
Haha great. I did a clean install on my other laptop. Goothing I got a good ol XP back up
@Juss10 (Follow Me)
Pro-97
Thurston County, Wa
01-24-2009, 08:18 AM
Had no troubles installing or using the cable on either of my Vista machines with the included drivers - have not updated the driver yet from the FT website.
01-24-2009, 01:19 PM
Oh, and I might add, after the clean install of Windows 7, these programs would not install for me using Vista Compatibility mode, either.
-- Kevin
01-24-2009, 08:11 PM
I could be wrong but , I thought in another thread it was said not to use the driver cd that came with the rs 20-247 cable. let vista find the drivers and install on its own.
01-24-2009, 08:13 PM
That recommendation may stem from the fact that the cable comes with some pretty old drivers, while Vista will find the most recent drivers from the USB/Serial part manufacturer (FTDI's driver version 2.04.06, from March 2008).
01-24-2009, 08:20 PM
Over one weekend I installed both the RS cable and a Belkin serial-USB converter. One installed with the OS finding the right drivers, the other didn't - I might be mis-remembering which was which. It might have been the RS that Vista found an up to date driver for...
01-24-2009, 09:28 PM
As Don stated, Vista will find the right ones for the RS / GRE cable. I had downloaded the FTDI drivers ahead of time, to ensure it would work with Vista64 last year when I got it. If I remember right, XP does NOT find the driver. But, that was at least a year ago... Windows Update may be, well, updated.
-- Kevin
