Old 07-14-2008, 07:26 PM
Default Pro-2006
I have a Radio Shack Pro-2006 that has a bad power supply, are there replacements still avaliable thru Radio Shack or any other sources ?
Old 07-14-2008, 08:30 PM
barry008's Avatar
Default Pro-2006 Power Supply
I've noticed that recently there have been several Pro-2006's on Ebay for sale. You probably could buy one off of Ebay cheaper than you could get yours fixed. Good luck!
Barry
Old 07-15-2008, 07:39 AM
N1SQB's Avatar
Wink I have a Suggestion!
I have a Pro-2006. That happened to me. What I suggest to you is simple. Remove the transformer completely.If it is only a bad transformer and nothing else, run it on an external 12V/500mA wall wart. Not only will this cut down significantly the heat that exists inside the radio but it makes it lighter and easier to plug /unplug/ move around ect... Just so you know, any 12 V power source will work as long as you have the right polarity and barrel plug. Believe it or not, the same plug that operates the Uniden,785,BCT15,996 will work on it. Good Luck!
Manny
N1SQB - AMATEUR- EXTRA CLASS
G.M.R.S - WQLH214
IN GOD WE TRUST! EVERYONE ELSE,WE MONITOR.....
Old 07-15-2008, 05:06 PM
scanernutt, I have a power supply that is 12v/500Ma, so I tried it and it works !
Thanks for the info
Nick
Old 07-15-2008, 08:30 PM
N1SQB's Avatar
Default My Pleasure Nick!
Glad I could help. Just do yourself a favor, remove the bad internal one. You never know if there is a wire loose or burned or something. Either way, you get rid of excess weight.
Manny
G.M.R.S - WQLH214
Similar Threads
For Sale Pro 2006 rwl48 Old Classifieds Archives 18 05-21-2007 03:07 PM
Fs: Rs Pro 2050 & Pro 2006 jscurtis Old Classifieds Archives 2 01-15-2007 09:43 PM
Forum Ranking? eorange System-wide Administration 4 10-18-2006 07:10 AM
Radio Shack Pro 2004 or 2006 nsammon68 Old Classifieds Archives 2 09-15-2006 12:50 PM
FS/FT PRO 2006 W/Opto Board & DX394 W/Mods Wilf11 Old Classifieds Archives 2 07-04-2006 08:35 PM
