Originally Posted by AlabamaRS
look under "closed mode "& it will explain how to do that by hand or just check closed mode tab in win97 on that bank
I think the O.P. is looking for a way to monitor only a particular talkgroup, not "all talkgroups he has programmed but not locked out" (which is what Closed Mode would give him).
I don't believe the PRO-97 will do this (navigate to particular talkgroup while it's not active, then monitor traffic on that talkgroup). However, it's been a while since I've used my PRO-97 as my primary radio. The PRO-97 manual does not describe a way to do it, though the PRO-96 manual does.
EDIT:
n2mdk posted the procedure to activate the PRO-97's "ID Hold mode" (while ID not active) below.
