All,
I recently purchased a Pro-106 with the intent of monitoring two digital systems in Phoenix, AZ, one of which is the "Phoenix Regional Wireless Network". It is a simulcast P-25, 9600 control channel and many of the digital channels are, if my information is correct, CQPSK encoded. The other site, Maricopa County, uses the older control channel and C4FM, again, if my information is correct, and it comes in fine.
I cannot get good reception on the PRWN regardless of which site I use, the one closest to my house isn't that far away, and while the control channel always comes in strong, the moment someone keys up I get a few syllables and that's about it. The radio display flashes between VC and DG, occasionally staying on "DG" for a few seconds but I get no audio even though it says it is locked on with a good signal.
So I emailed GRE, since they made the thing..and they basically shot back with a "We can't help you, go to radio shack". Pffft, thanks so much, GRE.
I'm about ready to return it since for my needs it is a $500 paperweight. But before I do, has anyone else in Phoenix had this problem and found a solution? Or are there somethings anyone can suggest I try? I've played with the attenuation and some other setting designed to 'enhance' digital reception without any improvement.
Chris
Chris
