Old 12-27-2008, 02:21 AM
pogbobo's Avatar
Default pro 106 STARS programming by hand
I just picked up a 106 for the $299 sale price a couple of days ago
a few of the local digital TRS's are coming in great ... so now I am after STARS ... I don't have the cable yet so I wanted to throw the Fork Mtn site in by hand ... any suggestions? I tried it as P25 auto and put in all the listed freqs and I'm using a Wildcard TGRP but it doesn't seem to be working very well I'm open to suggestions, I tried searching for help with the psr500 and stars but couldn't find much in the way of entering the system in manually ...
thanks in advance!
-Matt
Uniden BCT15 and BC246T . Kenwood TK-3160 and 260G . RS Pro-106
Old 12-27-2008, 10:11 AM
fmon's Avatar
thanks in advance!
Hi Matt, welcome to a great scanner.
Set
1. STARS TSYS to P25 Auto
2. Enter control freqs in your range.
3. Map Talkgroup Objects to the TSYS and insure a scanlist is selected.
4. Run scanner to populate Trunking Tables. It will only take a few seconds. (if you have a CC in range)
5. If none are in range, you can either wait until you are in range or set the tables as follows:
Code:
Lo Ch   Hi Ch  Offset    Base Freq     Step
0       4095     0       851.006250    6.250
4096    8191     4096    762.006250    6.250
8192    12287    8192    136.000000    2.500
12288   16383    12288   146.000000    2.500
16384   20479    16384   156.000000    2.500
20480   24575    20480   166.000000    6.250
24576   28671    24576   136.000000    6.250
28672   32767    28672   161.593750    6.250
You can likely get by with just the three settings using step 2.500 KHz.
Frank
RR Wiki Programming Shortcuts
Old 12-27-2008, 10:28 AM
fmon's Avatar
Are you able to hear a CC on Fork Mt?
To set tables.
Ring up the TSYS
PGM
EDIT
CURR
Down to the TSYS
SEL
FUNC Down
T Tables Right to Custom
SEL
SEL again on Table 01 Then edit the data in my previous ENT after Step then Save.
Down and SEL on Table 02 and repeat as above through all tables.
Frank
Old 12-27-2008, 04:17 PM
pogbobo's Avatar
thanks Frank!
when I goto analyze its showing Sy: between 99% and 75%ish ... its been at 99% for a few minutes now ... (on 152.7125)
I went into all the custom tables and it seems they propogated with all the values you listed!!
here is what I have so far:
P25 Auto
I entered all the freqs for Fork Mtn
1 TGRP with Wildcard, scan list enabled and scanning
Custom Tables that matchs all of your listed values
and I'm getting 99% decode on 152.7125
also, the T in the upper left seems to flash wildly all the time (the SMeter is full to full-1 consistantly as well) ... and does it make a difference what the Multi-Site setting is set to?
Thanks again for all the help!
edit:
ok, now I'm not getting the T at all ... signal is good, the S is flashing wildly ... but no T ? ... if I go to analyze for like 30 sec it starts receiving T data, but only around 40-60% ... whats going on here?
-Matt
Old 12-27-2008, 07:36 PM
fmon's Avatar
edit:
Is scanner in same location?
I couldn't find it, but thought I saw a thread regarding Fork Mtn problems recently. However, I pick it up in the area of MP 35 on I-64 when traveling to/from my annal pilgrimage to Kansas.
Frank
Old 12-28-2008, 03:25 AM
pogbobo's Avatar
yep, same place I allways am when not at work, sitting in my recliner
it is odd though, once I pick up voice transmissions it seems to normalize ... but before that, the T symbol is erratic and the decode % is very low ... oh well, what can you do
-Matt
Old 12-28-2008, 05:41 AM
pogbobo's Avatar
hey Frank, do you know if you have to enter all the listed freqs for a site, or can you just enter the control channel?
thanks!
-Matt
Old 12-28-2008, 10:24 AM
fmon's Avatar
thanks!
Controls only for Mot or P25, all for ED and LTR and latter two require separate TSYS for each site.
BTW, we get 99% on Hampton tower with a 500 and 197 sitting here. Only get about 54% on 2096 using same antenna through an electron 1 in 4 out box. 4th out is to a 785D. Hampton tower is 9 air miles. We get about 94% on Chesapeake tower at 17 air miles. The 2096 gets about 46%. However, even sitting near any STARS tower, the 96/2096 will rarely get above 74-78%.
Frank
Old 12-28-2008, 05:20 PM
pogbobo's Avatar
i see ... thanks for the info!
can I put in multiple ctrl channels for diff stars sites in the same TSYS? and set it to roam or whatever the setting is?
and on the same subject (sort of), can you use the same TGRPs for multiple TSYS as in the case of a multisite networked edacs site, such as the Central Planning District system? My BCT15 is great about having multiple sites that all used a collective pool of TGIDs for that system! ... any hints on this with the pro106?
-Matt
Old 12-28-2008, 06:25 PM
fmon's Avatar
Yes, that is how I have it set.
ED and LTR requires a new TSYS for each site and duplicating any common talkgroups mapped to each. If desired, these can use the same scanlist.
Frank
Old 12-28-2008, 06:26 PM
pogbobo's Avatar
gotcha ... thanks again for the help and good info!
-Matt
Similar Threads
Pro 96 original programming file needed rdaufan Radio Shack Scanners 1 10-29-2008 10:07 PM
Pro 97 Scanner Programming Question dpoynter02 Radio Shack Scanners 7 08-24-2008 05:10 PM
PRO 96 programming cable boom38 Radio Shack Scanners 2 08-04-2008 08:06 AM
WTB Pro 96 Programming cable. pennellamichael Old Classifieds Archives 0 07-28-2008 07:37 PM
Programming Advice - Need a hand RESQ19 Delaware Radio Discussion Forum 2 01-01-2005 06:07 PM
