Originally Posted by Have_Teeth
Way better Digital AGC than the 396 Makes a world of difference if the people running your local PS trunk are fools who don't read Motorola's technical briefs..
Using a Pro106 local SZ 4.1 system sounds much better running AGC off. Also a local PD (Astro conventional) sounded like crap with AGC on. You could hear background audio ramp up with AGC on. Had this problem in the past with a Pro96 I tested as well.
Uniden has better AGC in my opinion.
I do like some of the features exclusive to the 106.
Using programming cable as discriminator tap/slicer with UniTrunker.
Display conventional NAC codes
Ind ID display during trunking scanning.
Programming is different.
Uniden 396 allows groups in a system. For example, in my county there are 39 agencies. I can create a group for each agency and have the group alpha tag have the town's name.
On the 106 you can only name the scan list and conventional object. Not as flexible with alpha tagging. Also requires a lot more alpha tag editing on import from RR database.
Aside from that. I feel the 106 is a solid performer for the cost.
