Old 01-06-2009, 2:07 PM
Default PRO-2096 Firmware - Use 1.2, 1.3, or 1.4?
My new 2096 came with 1.2 installed. The RS site shows 1.3 and 1.4 upgrades available. (Actually 2 listed for 1.3. ???) There is no description given for the upgrade(s) as to what they add/fix. Is there any advantage/disadvantage to upgrading to a later version? Or, should I follow my old engineering professor's sage advice, "Don't f**k with success".
Joe
BC-250 (Currently Out of Order), PRO-37, PRO-43, PRO-2006
PRO-96, PRO-2096, PRO-106, PRO-197
Old 01-06-2009, 2:22 PM
Not Posting
If it works don't fix it. DSP v 1.3 was developed to fix a unique issue in Ohio, and Michigan. It wasn't quite right, then v 1.4 was brought out to correct 1.3. Last time I played with a PRO-2096 in S.E. Michigan I found v 1.2 still worked the best.
Old 01-06-2009, 2:25 PM
hoser147's Avatar
I use 1.4, you might try and see which one works the best for your area...
Good Scanning Hser
http://www.radioreference.com/apps/audio/?feedId=165
Old 01-06-2009, 2:29 PM
firmware??.. do you mean DSP or CPU? , latest DSP is 1.4 & is user upgradeable, CPU is 1.5 & is NOT user upgradeable.
Paul
P.S> if they should disappear from RS site PM me here I have all 3 dsp upgrades on my HD & will send to whoever may want/ need em
Old 01-06-2009, 2:49 PM
I think you hit the nail on the head as being correct.On the MPSCS v1.2 seems to work the best.There is the occasional short braaaap motorboating type sound on digital transmissions but nowhere near as bad as v 1.3 or v 1.4
You can load all versions of the firmware and determine wich works the best.If you want to revert to v 1.2 on the 2096 it's as simple as a few button presses.
Old 01-06-2009, 2:57 PM
fmon's Avatar
Silent Key Jan. 14, 2012
Joe, a pdf doc is in each download identifying purpose of upgrade.
Frank
RR Wiki Programming Shortcuts
Old 01-06-2009, 5:59 PM
Sinister's Avatar
From the Wiki
DSP APP Firmware Version U1.4 provides the following enhancement to your PRO-96/2096 Digital Trunking Scanner:
Improved digital decoding:
After upgrading to DSP Application firmware version 1.3 (DSP-APP 1.3), some users reported increased instances of the scanner failing to decode the beginning of digital transmissions on certain systems. DSP-APP 1.4 improves the performance of initial digital voice decoding and should result in fewer instances of undecoded digital noise at the beginning of transmissions. Under certain circumstances, such as when weak or distorted signals are present, the scanner may occasionally fail to decode the beginning of a digital transmission even after upgrading to DSP-APP 1.4.
If a radio consistently fails to reliably decode digital transmissions, users are advised to reposition the radio, utilize antennas designed for the specific band being monitored, such as the Radio Shack 20-283 800 MHz BNC antenna, or take other steps to improve the quality of the received signals.
Thanks Glenn
Forum Rules and Guidlines
NH Wiki
RR Moderator
Old 01-22-2009, 10:51 PM
cmdcomm's Avatar
Default DPS Upgrade problem
I can not get my 2096 or Pro-96 to go into firmware mode. I push and hold the prog button with the cable plugged in but it just goes to clone. Any ideas???
Old 01-23-2009, 12:12 AM
fmon's Avatar
Follow the steps in the pdf for upgrade. Then follow instructions on the upgrade.exe.
Frank
Old 01-23-2009, 7:40 PM
cmdcomm's Avatar
Default pdf?
I down loaded the 1.4 dsp from the RS website. It has 2 wordpad files, but no pdf file. I can not get the scanner to go into dsp program mode by holding down the "prog" button with the cable plugged in and turning it out.. Can someone send me the instructions or point me to the right place? I know the cable is working bc I can program the scanner.. HELP??? trying to get a new 800mhz p-25 simulcast system going....
Old 01-23-2009, 9:48 PM
fmon's Avatar
The pdf is in the download file, open it in Winzip or other zip program.
However, use the instructions in the upgrade file by doing steps 1 through 3 as in this image. If satisfied with the popup dialog click OK on it then proceed with steps 4 through 7.
Frank
Old 01-24-2009, 5:30 PM
Eng74's Avatar
I found the problem never mind.
Old 06-30-2016, 3:25 PM
Default pro 96 1.3 update
Paul
if you still have the 1.3 update for the pro 96 can you send it to me thanks
needham315@gmail.com
Old 07-03-2016, 10:13 PM
cherubim's Avatar
The 1.3 update was buggy. Not sure why you would want it.
I use DSP 1.2 on my Pro-96 and 2096 and it works the best for minimizing the digital motorboating.
Old 07-03-2016, 11:23 PM
Ronaldski's Avatar
MI DB Admin
A good ole 7 1/2 year old thread resurected.
1.4 - Pro-2096 - The RadioReference Wiki
Old 07-03-2016, 11:58 PM
Engine104's Avatar
I found that as well here in L.A. decoding the LAPD APCO system. The newer DSP upgrades would drop out on transmissions.
My call: KG6EJT. I've been scanning for over 30 years. I currently own a Pro-162, Pro-96, Pro-2006, BC-200XLT and the first scanner I ever owned, a Bearcat 210XL
Old 12-27-2017, 2:35 PM
rsnow22's Avatar
Paul
I have 2096 with 1.3 from factory. Need 1.2. 1.4 upgrade is available, but can'take find 1.2. Have looked on net, but have been told that can't go below factory. Have motorboating on digital channels. Have another scanner with 1.2 and it doesn't motorboat.
