Old 02-04-2009, 9:20 PM
n4yek's Avatar
Thumbs down Radio Shack Amplified Speaker
I went and bought one of these the other day after reading reviews on here and other places. I was expecting to see a great boost in audio from my 396T Uniden scanner. Boy was I surprised, not only do I get more audio from my OLD Un-amplified speaker, but I got a slight bit of alternator whine when I used the Amplified speaker and slightly less audio. That was a surprise, less audio and alternator whine. I could have built a filter to get rid of the whine, but to actually have less audio? I don't know what the gain is on that speaker but it was a disappointment to say the least.
Anyway it is going back and I am getting money back.
Anybody else have bad results? just curious.
Danny Harp Jr.
HAM Radio Operator: N4YEK
Old 02-05-2009, 3:49 AM
digitalanalog's Avatar
I've had one for about 10 years or so now, and it has been used and abused and still works and sounds good, no complaints at all.
-----> No Comment <-----
Old 02-05-2009, 6:33 AM
MaxTracker's Avatar
That's odd, I have one that's been kick, run over and abused also, And it works just fine. I have used it on my 97, 108, 898, 780 and other radio's and it makes a significant difference. Granted, its not a Motorola Amplified speaker, but works good. No suggestions for you other than try a different product by a different manufacturer.
MaxTracker
RR Feed: Texoma Regional Public Safety
Old 02-05-2009, 6:55 AM
xerb1962's Avatar
I have four of them. Been in use for years and I can >hear< my radios. There must be something wrong with the unit you bought?
Old 06-14-2012, 3:52 PM
just got one and it is great. I really dont think you can beat them for the price.
Old 06-14-2012, 4:14 PM
can you post a link so i can buy it?
KD0NDO
Metro Skywarn #7109, Sherburne Co ARES
-Martin
Old 06-14-2012, 10:55 PM
@KD0NDO.... Here is the amplified speaker model and part number at radioshack.com
RadioShack® Amplified Communication Speaker
Model:21-130 | Catalog #: 21-130 $38.99
" Leave the gun....take the cannolis "
Old 06-14-2012, 11:55 PM
gewecke's Avatar
Thumbs up
I've had one for years also,using it still. Modded it with a spst toggle to switch audio to second speaker in another room. Works great!
73,
n9zas
Old 06-16-2012, 11:11 PM
Might have got a bad one, did you take it back and get another one, Stores should have a 12 v outlet at the GPS display where you can test it in the store. There could be a problem with the cable from the radio to the speaker, did you try a different one? When power is applied to the speaker or the radio talks, did the red light on the front of the speaker, next to the K on Radio Shack come on? If not, check your power.
Doug
Pro2B/40/43/77/83/84/89/96/97(2)/99/106/107/137/164(2)/2026
BC235 BC245 SC230 ICR3, ICR10
+ HF, VHF & UHF Xceivers from Alinco Icom Kenwood Yaesu Vertex Maxon Mot & RS
Old 06-17-2012, 6:06 PM
UPMan's Avatar
IIRC, the speaker has a mono plug. You need to use a mono-to-stereo plug adapter when plugging it into a stereo headphone jack (otherwise you will be shorting out 1/2 of the scanners audio amplifier and the audio level will be 10-15 dB lower than when using a stereo plug).
Uniden Product Ninja
Professional Scanner Developer
