RS 20-047 Cable Pinout
K5RYA
Spring, TX
Does anyone know the pinout of the connectors on the Radio Shack programming cable (#20-047)? As in which parts of the ring/sleeve/tip are for rx/tx? Also is this cable basically a USB to RS232 to TTL device?
Evert
West River South Dakota
Yes, the 20-047 is “basically a USB to RS232 to TTL device”. The main chip is an FTDI FT232BL that does the USB to RS232 part.
As to the stereo plug pinout, I am pretty sure that the Radio Shack/GRE version follows the same pinout that FTDI uses on their complete USB to TTL cables such as the TTL-232R-AJ shown below for full-duplex mode. For half-duplex, the tip serves for both tx and rx.
K5RYA
Spring, TX
Thanks for the response. I managed to figure it out but I will save the diagram for future reference.
I managed to get my Minitor V programmed using my RadioShack programmer!!
So Far Away....
Evert..
You Rock Man,the need for this info arose only 6 minutes ago,now the pic's on my desktop..
good info to have on the RR forums,
Many Thank You's!
gmclam
Fair Oaks, CA
If you look at the signals from the cable, both ring AND sleeve are transmitted on from the PC.
