Old 05-01-2009, 11:04 AM
KF5DCI's Avatar
Default RS 20-047 Cable Pinout
Does anyone know the pinout of the connectors on the Radio Shack programming cable (#20-047)? As in which parts of the ring/sleeve/tip are for rx/tx? Also is this cable basically a USB to RS232 to TTL device?
BCD996XT, ICOM ID-800H
Old 05-07-2009, 8:16 AM
Yes, the 20-047 is “basically a USB to RS232 to TTL device”. The main chip is an FTDI FT232BL that does the USB to RS232 part.
As to the stereo plug pinout, I am pretty sure that the Radio Shack/GRE version follows the same pinout that FTDI uses on their complete USB to TTL cables such as the TTL-232R-AJ shown below for full-duplex mode. For half-duplex, the tip serves for both tx and rx.
Old 05-07-2009, 11:31 AM
KF5DCI's Avatar
Thanks for the response. I managed to figure it out but I will save the diagram for future reference.
I managed to get my Minitor V programmed using my RadioShack programmer!!
Old 11-14-2009, 12:19 PM
fourthhorseman's Avatar
Evert..
You Rock Man,the need for this info arose only 6 minutes ago,now the pic's on my desktop..
good info to have on the RR forums,
Many Thank You's!
Thomas's Grumpier German Cousin - Gustav the Railway Gun....
Old 11-15-2009, 2:01 AM
gmclam's Avatar
If you look at the signals from the cable, both ring AND sleeve are transmitted on from the PC.
PRO-95 | PRO-10 | PRO-97 | PRO-77 | PRO-92 | PSR-300 | PSR-310
