Old 06-02-2009, 03:04 PM
Default deleting preprogrammed frequencies pro-137
hello i know see why people have said the manuall sucks foe the pro-137 does anyone know how to delete the programmed frequencies all i see is lockout i would like to permantley get rid of these any help thanks.
Old 06-02-2009, 05:06 PM
On page 37 of the manual:
Resetting the Scanner
Caution: This procedure clears all the information
you have stored in the scanner. Before you reset
the scanner, try turning it off and on to see if it
begins working properly. Reset the scanner only
when you are sure it is not working properly.
1. Turn off the scanner. If you cannot turn off the
scanner, remove the battery and install again.
2. While holding down 2, 9 and SCAN, turn on
the scanner. Initializing…Please wait appears as
the scanner clears its memory.
Note: Do not turn off the scanner again until
Initializing…Please wait disappears. Otherwise,
the scanner might not clear its memory properly.
Similar Threads
FT: Radio Shack pro 137 1000 channel scanner and other stuff... SKYNET156 Old Classifieds Archives 0 04-21-2009 06:29 PM
Deleting Frequencies Bearcat95 Uniden Scanners 4 01-28-2009 05:09 PM
Programming Scanner Cable Git-R-Done General Scanning Forum 21 10-03-2008 02:26 AM
adding and deleting frequencies cdrens General Scanning Forum 4 09-16-2008 12:32 AM
Macy's and Department stores at Solano mall Arff312 San Francisco Bay Area Discussion 27 11-27-2007 07:47 PM
