Old 07-02-2009, 11:15 PM
antho10359's Avatar
Default Failure with Pro96 in Nashville, TN
I have a Pro96 and can't get it to work for Nashville - Davidson County. I have installed the latest firmware upgrade (UPG_14). I have tried both MOT 3600 normal and multitable. I use Win96 version 1.6.
I'm pretty sure I'm just missing something. Email me at antho10359@aol.com for a screen shot of my Win96 configuration but needless to say I am using all the frequencies and talkgroups listed for Nashville on RadioReference. I don't have any trouble receiving any other AP25/Mot digital systems. Any suggestions would be appreciated.
Old 07-03-2009, 09:34 AM
Not Posting
hmm make sure you have each channel programmed in MO mode & also the bank in MO mode. also each site in a different bank. also go ahead & program all the frequeencies, NOT just the cc's & alts. 3) post your p96 file here & let everyone take a look/ & last of all did you use the IMport feature to prograam or do by hand?
Old 07-03-2009, 12:27 PM
fmon's Avatar
FUNC + 3 is not required for your system.
When on control frequency manually, you should see M:36 5D1D xx% on bottom line.
Frank
RR Wiki Programming Shortcuts
Old 07-03-2009, 07:04 PM
antho10359's Avatar
Default Win96 File From Nashville, TN
I have the frequencies loaded in bank 4. See the attached Win96 File. Thanks for any help.
Old 07-03-2009, 07:49 PM
fmon's Avatar
You need to zip the file prior to upload or change it to .txt.
Frank
Old 07-03-2009, 08:56 PM
Not Posting
thats just change the File extention to .txt
Old 07-03-2009, 09:48 PM
antho10359's Avatar
Default File changed to txt
One more try
Old 07-03-2009, 10:25 PM
Not Posting
Check you email you have posted in the 1st message
Paul
Old 07-03-2009, 11:36 PM
fmon's Avatar
You have rebanded 800 MHz set in extended tables. Could be scanner is looking for other voice frequencies. Open Extended tables and check 800 MHz bullet which will set standard band plan.
Frank
Old 07-04-2009, 02:52 PM
antho10359's Avatar
The bottom line is blank for any and all of the Nashville frequencies.
Old 07-04-2009, 02:53 PM
antho10359's Avatar
Made the change via the extended table .... no difference.... just silence
Old 07-04-2009, 02:55 PM
antho10359's Avatar
Got the file and loaded it.... no difference for the Nashville frequencies ... just silence.... The Smyrna-Rutherford Cty digitals work fine though .... beats me .... Thanks for your help.
Old 07-04-2009, 03:10 PM
Not Posting
ok unless the 2 sites overlap & you can pickup more than 1 CC at the time, theres prob no need to put in seperate
e banks
Old 07-04-2009, 03:18 PM
fmon's Avatar
Then you do not have a control frequency in the list in bank 4, or you are no where in range of the transmitting tower.
Every thing else in this tread for Nashville depends on you getting this info (M:36 5D1D xx%) on line 4 when manually selecting the control frequency.
M:36 = MOT 3600 control channel
5D1D = SysID
xx% = decode rate of control channel
Even a 25% decode will get info.
Frank
Old 07-04-2009, 03:34 PM
antho10359's Avatar
I double checked and the listed control freq of 857.03750 and 855.9125 (as listed in this site's DB) as well as every other frequency are entered..... so I don't know what else to try.... I'm just outside the county line and monitored the analog signals for years (until the change to digital).
Thanks for all your help.
Old 07-05-2009, 10:59 PM
antho10359's Avatar
I changed antennas. The 4th line now reads M35:5D1D 33% however many of the transmissions are mostly grabled.
Old 07-05-2009, 11:07 PM
fmon's Avatar
33% decode rate will get a lot of garble. Get closer to the tower.
Frank
Old 07-29-2009, 11:55 PM
Check your email as listed earlier. My email will show doctree2@hotmail.com.
I will send you a working p96 file.
Doc
Similar Threads
Live Digital Feeds In Nashville TN TRamrod38 Tennessee Radio Discussion Forum 1 09-01-2008 11:06 PM
Nashville Gas (DBA Piedmont Natural Gas) Nashville TN nickbethea Tennessee Radio Discussion Forum 0 07-22-2008 03:47 PM
Low Band State Police by Frequency n2ops Skip / Tropospheric Ducting Forum 7 06-15-2008 12:36 AM
Nashville Tn ZOO stewart00311 Tennessee Radio Discussion Forum 2 07-11-2007 10:59 AM
BC246T in Nashville TN... problem? Brucedude Uniden Scanners 3 12-30-2006 10:14 AM
