Old 07-17-2009, 5:58 AM
RadMarv's Avatar
Thumbs down Radio Shack PRO-106 Product Support Page GOOF
Just checked the RS Product Support page for the PRO-106. They have posted two new FIRMWARE links.
INTERESTING!
BOTH DATED AS POSTED ON "JULY 09, 2009". (POSTED BUT NOT RELEASED)
Neither of the links work. They apparently embedded both links into ONE line.
Here's how the link is written...
<http://rsk.imageg.net/graphics/uc/rsk/Support/SoftwareDownload/2000106_0197_V17.EXE%3C%3E/Support/SoftwareDownload/2000106_0197_V17.PDF>
Both links are identical. The links are correct if edited as follows...
FOR THE FIRMWARE
<http://rsk.imageg.net/graphics/uc/rsk/Support/SoftwareDownload/2000106_0197_V17.EXE>
http://rsk.imageg.net/graphics/uc/rs...6_0197_V17.EXE
FOR THE INSTALLATION INSTRUCTIONS
<http://rsk.imageg.net/graphics/uc/rsk/Support/SoftwareDownload/2000106_0197_V17.PDF>
http://rsk.imageg.net/graphics/uc/rs...6_0197_V17.PDF
A simple enough goof to fix but to those who are just novices and don't read the available threads on the internet about the scanner they will endure a Radio Shack headache, especially if the links are NOT corrected rapidly.
OK WHERE'S THE PRO-164 BUG FIX FIRMWARE?????????? (?? STILL IN TESTING ??)
SCANNERS = PSR-500 - PRO-106 - PRO-96 - PSR-300 - PRO-94
ANTENNAS = DIAMOND RH77CA - WATSON W-881 - ST2 - HOMEMADE WIRE
SOFTWARE = WIN97 - WIN96 - WIN500 - WIN500REMOTE_CLIENT
Old 07-17-2009, 6:33 AM
That's asking them to step beyond the world of cellphones and batteries.........
Equipment:
A bunch of boxes of varying size with an array of knobs, buttons and displays (digital and analog), wires and stick-like things. Most make noise, and some I can even talk through!
Old 07-17-2009, 6:35 AM
DaveIN's Avatar
Founders Curmudgen
Did you contact RadioShack support about the problem?
RadioShack.com Helpdesk
Old 07-17-2009, 7:42 AM
and why is all this so "interesting?
Old 07-17-2009, 8:30 AM
N8IAA's Avatar
RadMarv--what bug fix for the 164?
Larry
Old 07-17-2009, 3:21 PM
RadMarv's Avatar
Larry
GRE and RS have release dates which are identical for the 1.06 firmware update. One month later GRE posted firmware 1.07 with the following information.
Latest release of PSR-300/400 "CPU G1.07" Firmware has been released.
CPU Firmware Version - G1.07 - 04/07/09
Corrected a problem with EDACS operation where certain control channel
frequencies would not track properly.
The frequency storing condition which generates the problem:
When the same frequency is stored in the control channel of Motorola System
and in the control channel of EDACS System, the software does not decode
EDACS Control Channel data properly.
Note: CPU Version G1.00-G1.05 does not generate this problem.
Old 07-29-2009, 4:43 AM
RadMarv's Avatar
TWELVE DAY'S LATER!!
The Radio Shack links to the PRO-106 firmware version 1.7 and instillation instructions have been fixed
Old 10-05-2009, 2:36 PM
cfr301's Avatar
How do you know if you need the firmware updates and does any one have the most recent correct links?
N/M I figured it out thanks!!!
