Old 09-03-2009, 3:22 PM
ac9f's Avatar
Default Pro 96 reband
Is there a site from Radio Shack that I can go to to download an upgrade to my Pro 96 for the new rebanding? Don't yell at me if this has been asked before, but I tried to search the site for the answer and did not find it.
Thanks in advance!!!!!
Chuck
AC9F
Old 09-03-2009, 3:28 PM
Wiki Admin Emeritus
No there isn't; our wiki has the correct procedure using the Win96 software, and it's documented at the bottom of the following (all links are blue)
Win96 - The RadioReference Wiki
I am told that ARC96 can also support this, but I don't know of anyone who's tried it yet.
73 Mike
Old 09-03-2009, 3:38 PM
ScanMemphis Forums-viewtopic-Radioshack PRO-96/PRO-2096 firmware update v1.4
I don't think you need the update for the rebanding as mentioned above, but why not get the update.... However, I am slightly convinced my Pro-96 worked better on the older version.
"Frankly, my dear, I don't give a damn..."
~Gone With the Wind
Terrell
"Ham radio is one of the few slices of insanity that you actually have to test into..."
Old 09-03-2009, 3:40 PM
milf's Avatar
Careful, I CAN hear you!
Yes ARC96 works fine with rebanding... I use both depending on the way I want to set up systems... With Win96 I have the option to set up to a 4 second delay on TRS's...whereas the ARC only allows the 2 second delay globally no matter how many times you click for more lol. As for the firmware.. I have 1.4, and use the latest DSP update also... The latest version of Win96 is very good, and I have yet to find a bug on it.
APX6000XE
Old 09-03-2009, 3:54 PM
read this also http://forums.radioreference.com/rad...d-systems.html
