Old 09-22-2009, 12:16 PM
Default PRO-197 Programming Problems - MN ARMER
Anybody here have any advice for programming the 197 to monitor Minnesota ARMER ? I'm manually programming a friend's PRO-197 scanner. I thought I had the scanner properly programmed, but I'm getting nothing. I don't care to buy the cloning software as I own a PRO-96 and already own that software. I may just end up d/ling the 197 software and using the free trial. I'd rather feel the pride of doing it myself. Unidens weren't this difficult!
I haven't touched the Global settings.
I set TSYS TYPE to P25 AUTO and set the control channels for Dakota County control tower frequencies(mirroring the frequencies I have set in my PRO-96 and know work). I left everything else default
TGRPs that I set for TYPE: GROUP didn't seem to scan, so I set them to PRIVATE, and now they "appear" to scan. I messed with the LED settings, but pretty much left the rest alone.
The radio Scans. The display indicates that the radio is receiving a strong signal and is receiving Trunking Control Channel Data. It's just not playing anything. I turned the squelch knob all the way down and not even static comes across. I tuned in to weather radio and I get a strong signal using the stock antenna. Does anybody know if I set something wrong?
Old 09-22-2009, 12:46 PM
DaveIN's Avatar
Welcome to Radioreference Jackster42.
If you programmed it by hand, then you may not have created a "wildcard" for the scanlist.
Take a look at these Wiki articles for help:
Programming Shortcut PSR-500/600 RS Pro-106/197 - The RadioReference Wiki
Object Oriented Scanning tips - The RadioReference Wiki
Old 09-22-2009, 3:21 PM
rmiller818's Avatar
It needs to be set to group, private is for to receive I-CALLS.
Tags
armer, minnesota, pro-97, programming help
