Old 10-18-2009, 09:51 PM
danno2manno's Avatar
Default programming opp into pro 197
Just got back from the states and bought a 197 for $399 at radio shack. So now programming the thing is another story. I do not have a programming cable and want to listen to it now. How and what is the quickest way to program the opp (ontario). I live in paisley and would use the ki greatly kincardine control channel. Any help would be greatly appreciated.
Dan
Danno
Pro 2096
Old 10-19-2009, 11:23 AM
fmon's Avatar
Dan
Program TSYS as MOT VHF/UHF. Use the 1 page Programming Shortcut link under my signature.
Frank
RR Wiki Programming Shortcuts
Old 10-19-2009, 04:47 PM
N1BHH's Avatar
Send a message via AIM to N1BHH Send a message via MSN to N1BHH Send a message via Yahoo to N1BHH Send a message via Skype™ to N1BHH
You may want to check out the links contained in this article, also: Pro-197 - The RadioReference Wiki There is a plethora of information right here on this site to help you understand how to set up your scanner.
WQBX787 = GMRS
Pro2055 Pro94A Pro2006 Pro2015 Pro2021 Pro164
Yaesu FT-60R, 8000R & 8800R, Motorola MTX9250, Alinco DR635T
Old 10-20-2009, 10:19 AM
# 23. Down and key in Hi Chan: then F1
# 24. Down and key in Offset: then F1
Danno
Pro 2096
Old 10-20-2009, 10:23 AM
Default Thanks
Thanks for all the help but what does the sentences below mean??
# 22. SEL again and Key in 1st Lo Chan: then F1
Danno
Pro 2096
Old 10-20-2009, 11:10 AM
fmon's Avatar
At step 22 you get a prompt to SEL for Table 01: Do so, then enter data for step 23 through 26. Your system has three tables so continue to second table which requires SEL to start Hi Chan for this table. Third table requires you to start at 22 again using SEL
Remember, this scanner has a quarry as to what an entry means. Using FUNC + SEL at any point will provide a short description of what you need to do. After reading the description, press SEL again to go back to entry.
Frank
