| Radio Shack Scanners A forum for the discussion of all Radio Shack scanning radios and receivers. |
10-20-2009, 11:13 AM
Can a pro97 be Rebanded?
I don't want to have to buy a new scanner, so is there any possible way a pro97 can be Rebanded?
10-20-2009, 01:58 PM
No, it can not be firmware upgraded, so the band plan is hard coded into the radios CPU. You would need to replace the CPU to do so.
10-20-2009, 02:12 PM
If you are going to buy a NEW scanner, I'd recommend the PSR-300. It is essentially the PRO-97 with some upgrades. You can even program it with WIN97.
PRO-95 | (customized) PRO-10 | PRO-97 | PRO-77 (customized) | PRO-92 | PSR-300
10-20-2009, 03:27 PM
Or the Pro-164 which is the new version of the 97.
Too darn many scanners;
2-BC4-6 Thin Scans, 4-BC100 Originals, 2-BC100XL,
BC70, 2-Pro-96, 2-Pro-2096, BC210
Other toys; Mercedes SLK230, S320, C280.
10-20-2009, 04:03 PM
It can be rebanded only if it is an EDACS or LTR system. Simply enter the new frequencies with the correct LCN. Rebanding on a Motorola system is not possible with a Pro-97.
10-20-2009, 04:38 PM
Keep in mind that which systems the PRO-97 will work with after rebanding depends on the frequencies used on those systems. If, after rebanding, any frequency in use on the system between 851 MHz and 854 MHz has the number 0 in the 4th decimal place (i.e. 851.125 00), the PRO-97 will not receive all transmissions on that system. Any transmission that uses those frequencies will send the scanner off to another frequency.
Post a link to the system(s) you're trying to monitor and you can probably get a definitive answer.
10-20-2009, 05:54 PM
Pro-97, pro-164, psr-300
The PRO-97 CAN NOT be "rebanded".
However, you can use it to monitor trunked systems under any of the following conditions:
- You are monitoring an EDACS system
- You are monitoring an LTR system
- ALL of its frequencies for the MOTorola system you want to monitor conform to 8xx.xxx5 MHz. If the system has any frequencies used for voice which are 8xx.xxx0 MHz, it will not track them.
So is the PSR-300! (the PRO-164 and PSR-300 are the same radio) The difference is you get support from GRE for the PSR-300 and from RS for the '164. The PSR-300 comes with an AC power adapter. Wait for a sale, the GRE model is a better deal.
10-20-2009, 09:20 PM
makes you wonder why they did not just allow you to set up tables for 800 band like you can do for 400.
you know industry probably had a heads up on rebanding long before we ever heard about it.
at a minimum they should have had an idea something like this was going to have to come down the pipe.
Thank You,
James_Bond_007
10-20-2009, 09:49 PM
KE4ZNR@radioreference.com
Actually they didn't. Rebanding has been a learning process for everyone involved including Public safety, Sprint/Nextel, GRE & Uniden. Considering that the Pro 97 was released when rebanding was in it's infancy no one had any idea how the process would go.
So I guess by your mindset GRE & Uniden should guess how comms will be 15 years into the future and plan accordingly, right? When you get that flux capacitor working in the Deloran then I am sure the radio companies will be glad to try to accommodate such requests.
Until then they have to do the best they can at the time the radio is manufactured.
Marshall KE4ZNR
10-21-2009, 08:30 AM
Originally Posted by mikey60
Keep in mind that which systems the PRO-97 will work with after rebanding depends on the frequencies used on those systems. If, after rebanding, any frequency in use on the system between 851 MHz and 854 MHz has the number 0 in the 4th decimal place (i.e. 851.12500), the PRO-97 will not receive all transmissions on that system. Any transmission that uses those frequencies will send the scanner off to another frequency.
Good point Mike. The rebanding situation could be different for your area. It just means your going to have to do your homework before you scrap and sell off your radio, or use it for a discriminator tap for decoder programs. Keep in mind if you have regular LTR systems, the PRO-97 can display the home repeater number if you park on the repeater frequency in the LTR mode.
