Old 10-20-2009, 08:47 PM
Default pro 2022 ant
what is a good ant for the pro 2022 that will pick up better then the stock one is the diamond rh77ca a good one
Old 10-21-2009, 08:40 AM
DaveIN's Avatar
Welcome to Radioreference ltfpfd. I use Diamond discones and Scantennas for my base models. There are many different brands available. Take a look at the Wiki for more information:
Scanner Antennas - The RadioReference Wiki
Old 10-21-2009, 09:29 AM
MPSCS's Avatar
Yes, for VHF/UHF bands, the Diamond RH77CA is an excellent choice.
Old 10-21-2009, 11:26 AM
N1BHH's Avatar
Send a message via AIM to N1BHH Send a message via MSN to N1BHH Send a message via Yahoo to N1BHH Send a message via Skype™ to N1BHH
If you are using it at home and really wish to have better reception, try an antenna outside. That is always best. It can be a simple mag mount and can range all the way up to a huge antenna on a tower. But that's really overkill, unless your out in the sticks. I have the Pro-2021, which is very similar to yours and it's only using the supplied telescopic whip and receives just fine sitting on the table next to my bed. It's only a few feet above ground level and I have satisfactory results with it. It's not my primary scanner, just the bedside scanner that I usually only scan a few channels overnight.
WQBX787 = GMRS
Pro2055 Pro94A Pro2006 Pro2015 Pro2021 Pro164
Yaesu FT-60R, 8000R & 8800R, Motorola MTX9250, Alinco DR635T
