| Radio Shack Scanners A forum for the discussion of all Radio Shack scanning radios and receivers. |
10-22-2009, 01:39 PM
EDAC channels
I am having problems programming EDAC channels on my Radio shack pro 2052 scanner. Do I need to use a computer program to do this?
10-22-2009, 09:31 PM
Hi jayoellig welcome to RadioReference
Make sure that the EDACS system that you are programming is starting at a channel that ends with a 1.
(channel 001 in Bank 1, 051 in 2 , 101 in 3...etc)
You must program at the beginning of the bank and no where else within the bank. It just won't trunktrack otherwise.
That was a mistake I made with the 2052,(my first trunktracking radio) I wanted conventional channels first then decided to plunk the EDACS in the middle of the bank and soon found out that it didn't work that way.
10-23-2009, 12:25 PM
The fire freq are Lebanon county, PA
10-23-2009, 12:52 PM
when i programmed he freq it sounds like i have an open mic reception
10-24-2009, 01:07 PM
Edac
do i just program the freqs of the south system and thats it. The data button makes no difference
10-24-2009, 07:47 PM
Yes,select a bank, then hit the TRUNK button and wait for it to beep twice.
Use the up or down arrow button and find Ed for EDACS trunk mode, press E
Enter the first freq. from the South site from the DB link, carry on until you get to the seventh and final freq.
Hit the SEARCH button, talk groups will show up, either in AFS form (04-021) or DEC for decimal (529)
It is a matter of preference on what you want to see.
The database here on RR prefers AFS and the radio probably will default to that display as well.
Good Luck
10-25-2009, 01:05 AM
To add to what mciupa has said, any of the digital TG's that the scanner will not decode can be locked out by pushing the L/Out button. Your county has gone to EDACS ProVoice. There is no scanner, even digital, that can decode the "D" type TG's. Most of your county is analog. So, that shouldn't be a problem.
Larry
Pro-106, Pro-163, Pro-99, Lafayette 200A, ScanFare VHF 4Ch Xtal, FT-60R
10-25-2009, 08:55 AM
so you are telling me that my 2052 scanner will not work
10-25-2009, 08:57 AM
i did what mcuipa directed me to and i had no difference. still had an open mic sound
10-25-2009, 09:54 PM
Yes, that is what I was trying to tell you
Larry
10-26-2009, 07:52 AM
any suggestion to one that will work
10-26-2009, 09:12 AM
what makes it possible that i get some transmissions on my 2052 on EDAC
10-26-2009, 11:23 AM
Please check that this is the case, especially since you claim to be hearing tx's.
10-26-2009, 11:45 AM
is there any way you can help me with the programing i spent 3 hr yesterday and got ... with it
10-26-2009, 12:04 PM
do i need to put IDs on these channels
10-26-2009, 02:38 PM
got it working
I hand wrote a list of IDs while on search mode. is there anyway to program those so i dont have to stay on search mode.
10-26-2009, 09:54 PM
Yes , put the scanner in Scan mode push Manual, a scanlist will appear each bank has 5 of them with 10 talkgroup ID's. They may be blank and look like this
1 - - - - -
That is where you put in the ID's you wrote down.
so if you want to enter 04-021 push these keys: 0 4 . 0 2 1 then E to enter it in the list.
Push SCAN and only what you programmed in will be heard rather than everything like when you are in SEARCH mode.
