Just taking a quick glance at the system, if you are traveling through any of the zones which have the same system ID, you could put the zones all together. If they have different system ID's, then they need separate banks. Because, here in Massachusetts, the State Police operate on a statewide system of Smart Zones and because there are other systems that use some frequencies used in some of the zones, you have to eliminate those control channels if setting up a statewide bank in your scanner. But you can set up those in another bank which you can turn off when you are in the zone you wish to monitor.
So here we have one System ID, in North Carolina you have 4 System ID's. You can decide to put each zone in it's own bank or put them together in one bank, depending upon what the System ID's are. Of course if one zone has loads of activity and the others don't then you may want to separate them geographically. It's all a matter of what and how much you want to listen to.
WQBX787 = GMRS
Pro2055 Pro94A Pro2006 Pro2015 Pro2021 Pro164
Yaesu FT-60R, 8000R & 8800R, Motorola MTX9250, Alinco DR635T
