Originally Posted by HancockCountyHal
The RadioShack Pro-197 specs do not state that it is compatable with LTR trunking systems.
(at least that I can find)
From the RR.Wiki, general specs on the Pro-197:
The Pro-197 is manufactured for Radio Shack by GRE America Inc.
The Radio Shack PRO-197 is a Digital Trunk Tracking scanner which boasts the ability to track APCO 25 digital trunking systems, in addition to following Motorola type I/II systems, LTR and EDACS trunking systems. It is very similar to the GRE PSR-600.
From page 14 of the Pro-197's Owner's Manual:
Multi-System Trunking – Scans most common trunked radio system signaling formats, including Motorola, EDACS, LTR and P25 trunked radio networks. Both talkgroup and individual call monitoring are supported.
LTR Home Repeater AutoMove – Takes the guesswork out of programming LTR trunking systems when the home repeater order is not known. Enter the LTR system frequencies in any order, and the PRO-197 will automatically move the frequencies to the proper home repeater slots as transmissions are received on the system.
If you can read this, thank a teacher - If you are reading it in English, thank a veteran.
Drive no faster than your guardian angel can fly.
Time has a way to corrupt everything.
Reason: Add More Info
