Old 02-04-2010, 06:49 AM
Question pro-106 and ids
how do you manually put in ids in a pro-106 and turn it off wildcard and get it to monitor the ids you put in
I know not what ye men take but as for me give me liberty or give me death
Old 02-04-2010, 11:11 AM
kayi4cle's Avatar
This was recently discussed here:
Pro 106 help!!!
Please let us know if you have further questions :-)
Old 02-04-2010, 04:02 PM
so basically if you want the open option you have to first dupe the wildcard then dupe all the ids after you put them in and if you want to close it you just lockout the wildcard?
Old 02-04-2010, 04:52 PM
kayi4cle's Avatar
If you want to listen ONLY to the IDs you programmed in (closed option), then you must disable the wildcard. You can do this by locking it out, deleting it, or editing it to change it from wildcard to an actual ID. Don't worry, because you can always use the DUP function and make another wildcard whenever you want. (I have done it all three ways, but I now prefer to just lock it out and keep it handy.)
If you want to hear all active IDs, including the ones you programmed in with your text tags, you must keep a wildcard unlocked (open option). This is a good way to find new IDs, or to check on what you are missing by hearing only your programmed IDs. You can simply go to your wildcard and unlock it from time to time to do this, and then lock it back whenever you want.
I hope this helps.
Old 02-04-2010, 05:43 PM
you have help me alot i am starting to understand this why do you have to dupe because there is more than one tower
Old 02-04-2010, 05:52 PM
kayi4cle's Avatar
No, sorry my explanation was confusing, and it has nothing to do with towers! The DUP feature I was referring to is a way to make new IDs without having to start from scratch every time. Using an ID that you already have, you choose DUP and then you only have to edit the ID number (and the text tag, if it needs to be changed). It is a very fast way to program a bunch of similar IDs manually. It is explained on page 37 here:
http://rsk.imageg.net/graphics/uc/rs...0106_PM_EN.pdf
As the manual says, it refers to talkgroups on the SAME trunked system (and you can also use it on conventional frequencies that are similar).
Old 02-05-2010, 08:24 AM
Ok i got the ids in but now my question is if you program a system that has four tower sites should you turn on the mutisite feature?How does this work?
Old 02-05-2010, 12:14 PM
kayi4cle's Avatar
I don't know. I've never done that. I guess you'll need to refer to the Manual page 82: "Multi-Site Mode on Networked Systems". Good luck, and happy scanning!
Old 02-09-2010, 02:32 PM
anyone have any idea how many ids each scanlist will hold on the pro-106?
Old 02-12-2010, 11:20 AM
Nobody?Does anyone own this scanner?
Old 02-12-2010, 11:40 AM
Since the scanner will hold 1,800 objects at a time, if each ID is counted as an object, I would assume a maximum of 1,7xx (I guess each frequency would also count as an object, so it would be 1,800 less the # of actual frequencies programmed)
Of course if you have multiple scanlists, you would only be able to hold a total of 1,800 so it depends on how many you put in each scanlist (e.g. 10 scanlists with 170 or so ID's each?)
I hope that is correct - someone else jump in here if I am wrong
Old 02-12-2010, 12:00 PM
Any scannable object (i.e. everything you can program except a TSYS ('trunked system') object) can belong to any, all, or none of the 22 scan lists (including 'Favorites' and 'Skywarn').
Apart from the hard memory limitation of 1852 objects, there is no limit to the number of objects that can be in any given scan list.
