Radio Shack Scanners -
A forum for the discussion of all Radio Shack scanning radios and receivers.
03-08-2010, 12:58 PM
how do i program my pro-197 scanner
can any help me in programing my pro-197 scanner ?
no help from Radio shack
03-08-2010, 6:10 PM
Coloradomom, as I mentioned to another poster, I can't recommend becoming a premium subscriber here at RR and getting the usb programming cable along with either PSRedit500 or Win500 for programming the radio. Of course it can be programmed manually by hand, but using the software and premium subscription will not only make programming it fast, but will greatly simplify programming it as well. I have the handheld version, the Pro106, and would hate to think about programming several systems into it by hand, but using the above mentioned software, cable, etc... it only takes a few moments to add entire systems, edit current ones, etc...
03-08-2010, 8:02 PM
Yes we can help, do you have a cable and software? What area are you needing to program?
Pro-2096
Pro-106
(3)Pro-197
BCD396XT
03-08-2010, 8:27 PM
I do not have the program or cable . I was told by radio shack that this scanner was programed to bent county,colorado.
03-09-2010, 7:36 PM
I got my UBS CABLE ,BUT RS DID NOT HAVE A PROGRAM
03-09-2010, 7:50 PM
You can try this software, but, there are others:
Win500: PSR-500, PSR-600, PRO-106, PRO-197 Scanner Software for Data Management, Monitoring, and Control
And use this guide to help import into the software and uploading to your scanner:
WIN500 - UtahRadio
03-09-2010, 7:58 PM
I didn't notice until now, you'll need to be a Premium Subscriber on RadioReference to use the import feature of the software.
03-11-2010, 12:17 PM
I would like to thank every one for there help in this matter.
My pro-197 is up and running.
I programmed it my self by looking up local frequencies ,and digital frequencies .and put them into my scanner,and they work just fine.
THANK YOU
03-13-2010, 8:53 AM
THANK YOU
Most excellent! Well played.... Maybe Radio Shack should hire YOU
Steve
N3VRX
03-13-2010, 1:03 PM
The program i would like to have is for south east colorado,Otero,crowley,bent ,prowers,baca,kiowa
02-06-2012, 6:30 PM
I have a Pro-197 and im woundering how you program a tsys that has default and splinter freq. in it?
Like Wabash County Tsys.
02-07-2012, 12:20 AM
WQWJ272 = GMRS
Pro's 94, 106 x2, 164, 197 x2 , 2006, 2015, 2021, 2055
02-07-2012, 6:06 PM
Thanks I'll give that a shot!
Thread Tools |
Display Modes |
