| Radio Shack Scanners A forum for the discussion of all Radio Shack scanning radios and receivers. |
07-26-2010, 1:24 AM
Discriminator Tap PRO106-Pics Included
Was bored today and my 106 was in need of a common BNC connector repair,seems the BNCs center pin lug broke from the antenna wire..so after i swapped the wire out for shielded flexible cable i decided to tap the disc output-TestPoint4...
hope you like the pice,,
the first is of the tap itself,,
second of the tap installed..
<img src="http://www.kiloecho1.com/Tapped=106.jpg">
>>>AR8200MKIII-DJG5-PRO106-PSR310-PSR800-RTLSDR/HamItUp<<<
07-26-2010, 1:34 AM
Here you go.
73 de W6KRU - Dan
BCD396XT BCD396T PSR-500 FRG-100 PRO-43 PRO-90 PRO-2050 FT-857 FT-90 VX-170 VX-3
RS 20-176 | Maxrad MFB8133 MYA8256 MUF8043 MLB3400
07-26-2010, 1:47 AM
lol..thanks mate,,
07-26-2010, 5:03 AM
Wiki Admin Emeritus
Hmm...this could go into the wiki - one vital piece of information is missing, though. Where precisely is TestPoint4?
I like the idea of putting the cap and resistor on a little breadboard, but it had to have been a tight fit to find the right spot to put that on top of something (?) that wouldn't short it out.
Interesting...73 Mike
07-26-2010, 5:29 AM
Nice Job!
Very well done!
Would love to see some pictures of the audio connector already installed on the scanner. By the way, I have always used a 10K resistor in my scanners. I see you used a 47K resistor. Any reason for that? Just curious....
Manny
N1SQB Amateur Extra
The difference between men and boys, is the price they pay for toys...
BCD996XT, BCT15X,396XT,346XT,GRE-PSR 310,Grundig G3,ICOM IC-7000,Motorola CDM1550LS+VHF/UHF,HT-1250UHF
07-26-2010, 9:29 AM
1st,Thanks!
No specific reason for hte 47,got the recipie from a member here and its worked well,,
Ive used 100k,and have been thinking about going down to a 10 to maybe get a lil louder audio
to flow through..
ill snap some more pics and post em soon
TP4,
the location of TP4 is in another wiki,its exactly the same as the PSR500,,matter o fact the service manual
for the 106 has an error for the LOGIC board page,it shows the PSR500 LED and keypad layout not the 106s..
heres a blueprint of the area you queried..
07-26-2010, 10:00 AM
heres the black n white page,zoomed..
07-26-2010, 12:07 PM
Wiki Admin Emeritus
Outstanding. Should be a cinch to copy these images into the wiki - I'll put a little explanatory text around it, and away we go. Should be helpful when this question comes up again - and no doubt, it will
73 Mike
07-26-2010, 1:24 PM
Nice job.
Baker College Major:Criminal Justice
Monitoring Macomb,St.Clair, Wayne, and G.P.I.S.
"Dedication lies in the hands of those who are dedicated". 9-1-1 Certified hours completed.
07-26-2010, 1:40 PM
very Cool,,into the rr archives!
to make a coupel side notes,
I hot glue gunned the wiring on the taps PCB to strengthen the connection
and making it more workable.
I also double looped the output wire through a common radio-speaker magnet
to help reduce-clean up and RF interference(may have been unnecessary-couldnt hurt)
,shrink tubing it to keep from contacting anything on the PCB.
everything else is as pictured and straight forward,total process,with frequent
stops about 60 minutes.
thanks for the pos feedbacks,,and thanks to a rainy day time to do it!
07-28-2010, 5:41 AM
Originally Posted by ka3jjz
It would also be nice to have a picture of the jack from the outside of the scanner once re-assembled to complete the visual package. Once again, very nice work.
Manny
N1SQB Amateur Extra
12-02-2012, 11:50 PM
Hi,
Looking at the photo of the circuit board that resistor is a 47 ohm resistor, not a 47k
12-03-2012, 12:06 AM
Very nice job.
Thanks for posting!
73,
n9zas
12-03-2012, 9:17 AM
Nice job!
Mods: Can we get this thread stickied, since it is sort of a reference? I might be helpful to the folks who come along and want to know how to do this!!! (If not it's okay)
12-15-2012, 12:32 PM
Outstanding! I am trying to do the same thing. Can anyone or is there a YOUTUBE video of this procedure? It's been a nightmare for me chasing this. Can you explain-what if any kind of wire, or solder it to the board with prvided wire(s)? Thx-Ron-----3 106's to do
12-15-2012, 12:58 PM
I am seeing all kinds of layouts, but the question now is, I took the back off. There is a wire holding front to back. Do I remove the plate from the front part? I got up the gumption to open her up. As is-2 parts connected by 2 wires. I see all kinds of letters and numbers--none that have tp..thx
12-17-2012, 7:36 PM
Can the pro 106 scan NXDEN as well with the tap?
